labels:
model: "some-juju-model"
The COS charm libraries wrapping any observability relation endpoint inject these labels into all outgoing metric, log, trace, and dashboard, so that the charm using them doesnât have to be aware of this at all. Any charm can ship with dashboards and (alert) rules to monitor its lifecycle. These are the so-called âbuilt-inâ dashboards and rules, and are workload-specific. When the charm is deployed and related to COS, the charm libraries mediating the COS integrations will automatically inject the juju topology labels in all built-in dashboards and rules.
Dashboards
When dashboards are forwarded through a grafana-agent intermediary, the juju topology labels of the charm of origin are injected (and not grafana-agentâs). Any subsequent chaining to additional grafana agent charms would leave the labels intact.
cos-proxy will apply its own topology to the labels, as old LMA-provider units donât implement the more modern interfaces that we would need to add topology to the telemetry.
Metrics
Alert rules
Alert rules are workload-specific and vary from charm to charm. For example, two different workloads can have an alert for âmemory running outâ, but with different thresholds. We need to qualify each alert rule with a different set of labels, so that when an expr evaluates as true, it only fires for the intended metrics.
For built-in alert rules,
- Alert
exprs are qualified with topology labels. This way, built-in alerts fire only for the particular charm they originated from. - Alert labels are enriched with topology labels. This is meant for convenient reading of a rendered alert when presented to an on-caller. The labels would also be visible in the alertâs rendered
expr, but alert labels are more convenient to read. - Alert rules are NOT enriched with the
unitlabel. This is because we wouldnât want to replicated all rules per unit. Unit information is included in metric and log labels. Since alert rules are forwarded to prometheus/loki per related app, not unit, having multiple units does not result in prometheus having duplicated alerts per unit. If an alert was qualified with a unit (which one?), we wouldnât get alerts from any other units. - Alert rules descriptions can use a
{{ $labels.juju_unit }}macro in the alertâs annotations, which will be replaced with the unit name for better readability.
When rule files are forwarded via grafana-agent, then they are enriched with juju topology labels of the relating charm (not grafana agentâs topology). Any subsequent chaining to additional grafana agent charms would leave the labels intact.
Logs
In grafana-agent, logs scraped from files, such as /var/log, will be tagged with the grafana-agentâs own topology, while logs coming from the snapâs slot will be tagged with the source unitâs topology.
Traces
If going via grafana-agent is not an option for you, you are yourself responsible for injecting juju topology into the root spanâs resource definition. As your workload will be forwarding traces straight into Tempo, and Tempo doesnât know where they are coming from, you should ensure that you can see that clearly in the spans themselves.
Additional notes
- In the future, the
grafana-agentcharm may start exposing metrics and logs generated by its own workload, and those would be enriched by juju topology labels. - In the future, the
cos-configurationcharm may start exposing metrics and logs generated by its own workload,git-sync, and those would be enriched by juju topology labels. - In the future (2025)
grafana-agentwill be replaced byotlp-collector. The general data flow should remain unchanged.
