COS Configuration Repository Operator for Kubernetes
cos-configuration-k8s is an auxiliary charm to the COS Lite bundle.
The charm facilitates forwarding freestanding files from a git repository to the following operators:
- Prometheus K8s charmed operator: Alert rules and recording rules
- Loki K8s charmed operator: Alert rules
- Grafana K8s charmed operator: dashboards
Internally, the charm is using git-sync to sync a remote repo with the local copy.
The repo syncs on update-status or when the user manually runs the sync-now action.
The charm lets you configure a gitops-style repo as a syncing source of alert rules and dashboards and can be readily integrated with Charmed Prometheus, Loki and Grafana.
This charm is:
- auxiliary to the COS Lite bundle
- intended to be used together with a git repository of alert rules and dashboards without topology labels.
In this documentation
| Tutorial Get started - a hands-on introduction for new users deploying the charmed operator. |
| Explanation Concepts - discussion and clarification of key topics |
Reference Technical information - specifications, APIs, architecture |
Project and community
The cos-configuration operator is part of the Canonical Observability Stack. It’s an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
- Read our Code of conduct
- Join the Discourse community forum
- Join the Matrix community chat
- Contribute on GitHub
Thinking about using the Canonical Observability Stack for your next project? Get in touch!
Navigation
| Level | Path | Navlink |
| 1 | Tutorial | Tutorial |
| 2 | git-ops | Sync alert rules from a git repo |
| 1 | How To | How To |
| 2 | deploy | Deployment |
| 2 | integrating | Integrating |
| 1 | Reference | Reference |
| 2 | solution-matrix | Solution matrix |
| 2 | Security | Cryptographic documentation for COS-Lite charms |
| 1 | Explanation | Explanation |
| 2 | topology-labels | Juju topology labels |
Redirects
Mapping table
| Path | Location |
