In COS Lite, Grafana Loki is the storage and querying backend for logs. Loki is optimised for write performance (ingestion speed), at the cost of slower random reads. This means that filtering structured logs by labels is fast, but full-text search is slower.
Log lines must be pushed into Loki, as Loki does not actively collect anything on its own.
Charmed operators are programmed to automatically add juju topology labels to all telemetry, including logs. This enables to differentiate telemetry and associated alerts, if you happen to have multiple deployments of the same application.
Send logs to Loki
In a typical COS Lite deployment, Loki would be running in a separate model from the monitored applications. While charms can we related directly to Loki using multiple cross-model relations (CMRs), we recommend funnelling all model telemetry through regular in-model relations to grafana agent, and only one CMR from grafana agent to Loki.
flowchart LR
subgraph COS
loki[Charmed Loki]
end
subgraph K8s model
loki-client["Loki client\n(LokiPushApiConsumer)"] ---|"logging\n(loki_push_api)"| grafana-agent-k8s
non-loki-client["Any workload + promtail\n(LogProxyConsumer)"] ---|"logging\n(loki_push_api)"| grafana-agent-k8s
end
grafana-agent-k8s[Charmed\ngrafana-agent] ---|"<a href=https://charmhub.io/loki-k8s/integrations#logging>logging</a>\n(<a href=https://charmhub.io/interfaces/loki_push_api>loki_push_api</a>)"| loki
click grafana-agent-k8s "https://charmhub.io/grafana-agent-k8s"
click loki "https://charmhub.io/loki-k8s"
subgraph VM model
vm-charm[VM charm] ---|"cos-agent\n(<a href=https://charmhub.io/interfaces/cos_agent>cos_agent</a>)"| grafana-agent[Charmed\ngrafana agent]
any-vm-charm[Any VM charm] ---|"juju-info\n(juju-info)"| grafana-agent
legacy-vm-charm[Legacy VM charm] ---|"filebeat\n(<a href=https://charmhub.io/interfaces/elastic-beats>elastic-beats</a>)"| cos-proxy
end
grafana-agent ---|"logging\n(loki_push_api)"| loki
cos-proxy ---|"logging\n(loki_push_api))"| loki
click grafana-agent "https://charmhub.io/grafana-agent"
click cos-proxy "https://charmhub.io/cos-proxy"
Send logs from k8s charms
Depending on your workload, you could choose one of the following charm libraries:
LokiPushApiConsumer, for workloads that can speak Loki’s push api.LogProxyConsumer, which would automatically inject a promtail binary into the workload containers of interest.LogForwarder: This object can be used by any Charmed Operator which needs to send the workload standard output (stdout) through Pebble’s log forwarding mechanism.
Example: postgresql
Charmed postgresql-k8s is using LogProxyConsumer to tell promtail to collect logs from:
"/var/log/pgbackrest/*",
"/var/log/postgresql/patroni.log",
"/var/log/postgresql/postgresql*.log",
When related to loki,
bundle: kubernetes
applications:
loki:
charm: loki-k8s
channel: edge
scale: 1
trust: true
pgsql:
charm: postgresql-k8s
channel: 14/edge
scale: 1
trust: true
relations:
- - pgsql:logging
- loki:logging
this results in an auto-render promtail config file with three scrape jobs, one for each “filename”:
$ juju ssh --container postgresql pgsql/0 cat /etc/promtail/promtail_config.yaml
clients:
- url: http://loki-0.loki-endpoints.test.svc.cluster.local:3100/loki/api/v1/push
positions:
filename: /opt/promtail/positions.yaml
scrape_configs:
- job_name: system
static_configs:
- labels:
__path__: /var/log/pgbackrest/*
job: juju_test_6a8318db_pgsql
juju_application: pgsql
juju_charm: postgresql-k8s
juju_model: test
juju_model_uuid: 6a8318db-33e9-487b-8065-4d95bfdabbdb
juju_unit: pgsql/0
targets:
- localhost
- labels:
__path__: /var/log/postgresql/patroni.log
juju_model: test
juju_unit: pgsql/0
targets:
- localhost
- labels:
__path__: /var/log/postgresql/postgresql*.log
juju_model: test
juju_unit: pgsql/0
targets:
- localhost
server:
grpc_listen_port: 9095
http_listen_port: 9080
Send logs from VM (“machine”) models
Use charmed grafana-agent, which is a subordinate charm.
- When related over
juju-info, it will pick up all logs from/var/log/*without any additional setup. - When related over
cos-agent, it will collect the logs specified in charm code, as well as built-in alert rules and dashboards.
Example: nova-compute
nova-compute does not make use of the charm libraries provided by charmed loki, so the method of integration is over the juju-info interface.
series: jammy
applications:
agent:
charm: grafana-agent
channel: edge
nc:
charm: nova-compute
channel: yoga/stable
num_units: 1
relations:
- - agent:juju-info
- nc:juju-info
This results in an auto-generated grafana-agent.yaml config file with juju topology labels and the default scrape jobs for /var/log/**/*log and journalctl:
$ juju ssh agent/0 cat /etc/grafana-agent.yaml
integrations:
agent:
enabled: true
relabel_configs:
- regex: (.*)
replacement: juju_test_608018cd-d625-40c8-8e27-8ac7eef7d94f_agent_self-monitoring
target_label: job
- regex: (.*)
replacement: juju_f7d94f_0_lxd
target_label: instance
- replacement: grafana-agent
source_labels:
- __address__
target_label: juju_charm
- replacement: test
source_labels:
- __address__
target_label: juju_model
- replacement: 608018cd-d625-40c8-8e27-8ac7eef7d94f
source_labels:
- __address__
target_label: juju_model_uuid
- replacement: agent
source_labels:
- __address__
target_label: juju_application
- replacement: agent/0
source_labels:
- __address__
target_label: juju_unit
node_exporter:
prometheus_remote_write: []
logs:
configs:
- clients: []
scrape_configs:
- job_name: varlog
pipeline_stages:
- drop:
expression: .*file is a directory.*
static_configs:
- labels:
__path__: /var/log/**/*log
instance: juju_f7d94f_0_lxd
juju_application: agent
juju_model: test
juju_model_uuid: 608018cd-d625-40c8-8e27-8ac7eef7d94f
juju_unit: agent/0
targets:
- localhost
- job_name: syslog
journal:
labels:
juju_model: test
juju_unit: agent/0
pipeline_stages:
- drop:
positions_directory: ${SNAP_DATA}/grafana-agent-positions
metrics:
server:
log_level: info
Send logs from legacy charms
Legacy charms are charms that do not have COS relations in place, and are using older, “legacy” relations instead, such as “http”, “prometheus”, etc. Legacy charms relate to COS via the cos-proxy charm.
Send logs manually (no-juju solution)
You can set up any client that can speak Loki’s push api, for example: grafana-agent snap.
Inspecting log lines ingested by Loki
Manually querying Loki API endpoints
You can query loki to obtain logs via HTTP API.
Displaying in a grafana panel
A Loki datasource is automatically created in grafana when a relation is formed between loki and grafana.
You can visualise logs in grafana using LogQL expressions. Grafana does not keep a copy of the Loki database. It queries loki for data, based on the expr in the panels.
Retention policy for logs in Loki
Loki does not have a size-based retention policy. Instead, they rely on a retention period. This makes sense from operational approach standpoint, especially since the design assumption is that user would be using S3 storage.
The default retention period is 30 days. At the moment the loki charmed operator does not support modifying this.
