Prometheus scrape config charm
The Prometheus scrape config operator is an adapter charm between metrics providers and prometheus.
The charm enables you to apply a set of configurations to the scrape jobs provided by its upstream charms, and forward the modified scrape jobs downstream to one or more consumers (e.g. prometheus) that will actually perform the scraping.
This charm is:
- an optional part of the COS Lite bundle
- intended to be used together with
prometheus-k8s
In this documentation
| Tutorial Get started - a hands-on introduction for new users deploying the charmed operator. |
| Explanation Concepts - discussion and clarification of key topics |
Reference Technical information - specifications, APIs, architecture |
Project and community
The prometheus-scrape-config charm is an optional part of the Canonical Observability Stack. It’s an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
- Read our Code of conduct
- Join the Discourse community forum
- Join the Matrix community chat
- Contribute on GitHub
Thinking about using the Canonical Observability Stack for your next project? Get in touch!
Navigation
| Level | Path | Navlink |
| 1 | Tutorials | Tutorials |
| 2 | deploy-cos-lite | Deploy COS Lite on MicroK8s |
| 2 | Usage | Usage |
| 1 | How To | How To |
| 2 | uncharmed | Integrate with external (non-charmed) workloads |
| 2 | integrating | Integrating |
| 1 | Reference | Reference |
| 2 | Deployment Scenarios | Deployment Scenarios |
| 2 | solution-matrix | Solution matrix |
| 2 | Security | Cryptographic documentation for COS-Lite charms |
| 1 | Explanation | Explanation |
| 2 | topology-labels | Juju topology labels |
Redirects
Mapping table
| Path | Location |
