Charmed Grafana (k8s)
grafana-k8s is a charm for Grafana.
It is an essential part of the COS Lite bundle.
This Charmed Operator handles instantiation, scaling, configuration, and Day 2 operations specific to Grafana, an open-source observability toolkit that includes a data visualization solution.
This operator drives the Grafana application, and it can be composed with other operators to deliver a complex application or service.
The charm imposes configurable resource limits on the workload, can be readily integrated with data sources such as prometheus, alertmanager or loki, and comes with built-in alert rules and dashboards for self-monitoring.
This charm is:
- part of the COS Lite bundle
- intended to be used together with prometheus and loki.
In this documentation
| Tutorial Get started - a hands-on introduction for new users deploying the charmed operator. |
| Explanation Concepts - discussion and clarification of key topics |
Reference Technical information - specifications, APIs, architecture |
Project and community
The Grafana charmed operator is part of the Canonical Observability Stack. It’s an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
- Read our Code of conduct
- Join the Discourse community forum
- Join the Matrix community chat
- Contribute on GitHub
Thinking about using the Canonical Observability Stack for your next project? Get in touch!
Navigation
| Level | Path | Navlink |
| 1 | Tutorials | Tutorials |
| 2 | deploy | Deploy charm |
| 2 | tls | Enable TLS |
| 2 | new-dashboard | Create a new dashboard for an existing charm |
| 1 | How To | How To |
| 2 | integrate-with-grafana-source | Integrate a datasource with grafana over grafana_datasource |
| 2 | charmed-dashboard | Best practices for charmed dashboards |
| 2 | modify-dashboards-air-gapped | Modify dashboards in air-gapped environments |
| 2 | troubleshoot-dashboards | Troubleshoot dashboards |
| 1 | Reference | Reference |
| 2 | relation-management-libraries | Relation management libraries |
| 2 | network-requirements | Network Requirements |
| 2 | solution-matrix | Solution matrix |
| 2 | Security | Cryptographic documentation for COS-Lite charms |
| 1 | Explanation | Explanation |
| 2 | topology-labels | Juju topology labels |
Redirects
Mapping table
| Path | Location |
