Grafana-operator-k8s docs - Get charmed Grafana up and running
To deploy Grafana using this operator you would need a juju microk8s controller bootstrapped.
Deploy Grafana
juju deploy --trust grafana-k8s grafana  # stable channel
--trust is required because the charm needs to modify grafana’s K8s resources.
Wait until the status settles to active/idle.
Verify deployment
Confirm the pebble service is running
juju exec --unit grafana/0 -- \
  PEBBLE_SOCKET=/charm/containers/grafana/pebble.socket \
  pebble plan
Obtain the admin password
juju run grafana/0 get-admin-password
# Or, programmatically,
juju run grafana/0 get-admin-password --format json \
  | jq -r '."grafana/0".results."admin-password"'
Query grafana endpoints
juju ssh --container grafana grafana/0 \
  curl localhost:3000
This should return Found.
List all dashboards:
  curl --user admin:$PASSWORD
  https://localhost:3000/api/search
