Prometheus scrape target charm
prometheus-scrape-target-k8s supports metrics aggregation
from applications outside any Juju model.
The charm facilitates using the Canonical Observability Stack even for use cases where the metrics endpoints do not originate from other charmed operators.
Generally, you should only use Prometheus Scrape Target when you only need metrics or for some reason you cannot deploy Grafana Agent, which is a more general, robust approach for observing external workloads. See how to set up COS Lite with Grafana Agent to monitor uncharmed workloads.
This charm is:
- an optional part of the COS Lite bundle
- intended to be used together with
prometheus-k8s
In this documentation
| Tutorial Get started - a hands-on introduction for new users deploying the charmed operator. |
| Explanation Concepts - discussion and clarification of key topics |
Reference Technical information - specifications, APIs, architecture |
Project and community
The prometheus-scrape-target charm is an optional part of the Canonical Observability Stack. It’s an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
- Read our Code of conduct
- Join the Discourse community forum
- Join the Matrix community chat
- Contribute on GitHub
Thinking about using the Canonical Observability Stack for your next project? Get in touch!
Navigation
| Level | Path | Navlink |
| 1 | Tutorials | Tutorials |
| 2 | deploy-cos-lite | Deploy COS Lite on MicroK8s |
| 2 | usage | Usage |
| 1 | How To | How To |
| 2 | uncharmed | Integrate with external (non-charmed) workloads |
| 1 | Reference | Reference |
| 2 | solution-matrix | Solution matrix |
| 2 | Security | Cryptographic documentation for COS-Lite charms |
| 1 | Explanation | Explanation |
| 2 | topology-labels | Juju topology labels |
Redirects
Mapping table
| Path | Location |
