Configuration > List of model configuration keys
See also: Model, How to configure a model
This document gives a list of all the configuration keys that can be applied to a Juju model.
Contents:
Generic keys
The table below lists all the model keys which may be assigned a value and are not specific to a single cloud.
Key | Type | Default | Valid values | Purpose |
agent-metadata-url | string | “” | The URL of the private stream. | |
agent-stream | string | “” | released/devel/proposed | The version of Juju to use for deploy/upgrades. |
agent-version | string | The desired Juju agent version to use. | ||
apt-ftp-proxy* | string | “” | The APT FTP proxy for the model. | |
apt-http-proxy* | string | “” | The APT HTTP proxy for the model. | |
apt-https-proxy* | string | “” | The APT HTTPS proxy for the model. | |
apt-mirror | string | “” | The APT mirror for the model. | |
apt-no-proxy | string | “” | List of domain addresses not to be proxied for APT (comma-separated). | |
automatically-retry-hooks | bool | true | Determines whether the uniter should automatically retry failed hooks. | |
backup-dir | string | “” | Directory used to store the backup working directory. | |
charmhub-url | link | The url for CharmHub API calls. | ||
cloudinit-userdata | string | “” | Cloud-init user-data (in yaml format) to be added to userdata for new machines created in this model. | |
container-image-metadata-url | string | “” | url | The URL at which the metadata used to locate container OS image ids is located. |
container-image-stream | string | released | url | The simplestreams stream used to identify which image ids to search when starting a container. |
container-inherit-properties | string | “” | List of properties to be copied from the host machine to new containers created in this model (comma-separated). | |
container-networking-method | string | local/provider/fan | Method of container networking setup - one of fan, provider, local. | |
default-series | string | focal | valid series name, e.g. ‘bionic’ | The default series of Ubuntu to use for deploying charms. |
default-space | string | “” | The default network space used for application endpoints in this model. | |
development | bool | false | Whether the model is in development mode. | |
disable-network-management | bool | false | Whether the provider should control networks (on MAAS models, set to true for MAAS to control networks). | |
disable-telemetry | bool | false | Disable telemetry reporting of model information. | |
egress-subnets | string | “” | Source address(es) for traffic originating from this model. | |
enable-os-refresh-update | bool | true | Whether newly provisioned instances should run their respective OS’s update capability. | |
enable-os-upgrade | bool | true | Whether newly provisioned instances should run their respective OS’s upgrade capability. | |
fan-config | string | “” | overlay_CIDR=underlay_CIDR | Configuration for fan networking for this model. |
firewall-mode | string | instance | instance/global/none | The mode to use for network firewalling. ‘instance’ requests the use of an individual firewall per instance. ‘global’ uses a single firewall for all instances (access for a network port is enabled to one instance if any instance requires that port). ‘none’ requests that no firewalling should be performed inside the model. It’s useful for clouds without support for either global or per instance security groups. |
ftp-proxy* | string | “” | url | The FTP proxy value to configure on instances, in the FTP_PROXY environment variable. |
http-proxy* | string | “” | url | The HTTP proxy value to configure on instances, in the HTTP_PROXY environment variable. |
https-proxy* | string | “” | url | The HTTPS proxy value to configure on instances, in the HTTPS_PROXY environment variable. |
ignore-machine-addresses | bool | false | Whether the machine worker should discover machine addresses on startup. | |
image-metadata-url | string | “” | url | The URL at which the metadata used to locate OS image ids is located. |
image-stream | string | released | The simplestreams stream used to identify which image ids to search when starting an instance. | |
juju-ftp-proxy* | string | “” | The FTP proxy value to pass to charms in the JUJU_CHARM_FTP_PROXY environment variable. | |
juju-http-proxy* | string | “” | The HTTP proxy value to pass to charms in the JUJU_CHARM_HTTP_PROXY environment variable. | |
juju-https-proxy* | string | “” | The HTTPS proxy value to pass to charms in the JUJU_CHARM_HTTPS_PROXY environment variable. | |
juju-no-proxy* | string | 127.0.0.1,localhost,::1 | List of domain addresses not to be proxied (comma-separated), may contain CIDRs. Passed to charms in the JUJU_CHARM_NO_PROXY environment variable. | |
logforward-enabled | bool | false | Whether syslog forwarding is enabled. | |
logging-config | string | The configuration string to use when configuring Juju agent logging (see this link for details). | ||
logging-output | string | “” | The logging output destination: database and/or syslog. (default “”) | |
lxd-snap-channel | latest/stable | The channel to use when installing LXD from a snap (cosmic and later). | ||
max-action-results-age | 336h | The maximum age for action entries before they are pruned, in human-readable time format. | ||
max-action-results-size | 5G | The maximum size for the action collection, in human-readable memory format. | ||
max-status-history-age | string | 336h | 72h, etc. | The maximum age for status history entries before they are pruned, in human-readable time forma |
max-status-history-size | string | 5G | 400M, 5G, etc. | The maximum size for the status history collection, in human-readable memory format. |
net-bond-reconfigure-delay | 17 | The amount of time in seconds to sleep between ifdown and ifup when bridging. | ||
no-proxy* | string | 127.0.0.1,localhost,::1 | List of domain addresses not to be proxied (comma-separated). | |
num-container-provision-workers | 4 | The number of container provisioning workers to use per machine. | ||
num-provision-workers | 16 | The number of provisioning workers to use per model. | ||
project | default | |||
provisioner-harvest-mode | string | destroyed | all/none/unknown/destroyed | What to do with unknown machines (default destroyed). |
proxy-ssh | bool | false | Whether SSH commands should be proxied through the API server. | |
resource-tags | string | none | A space-separated list of key=value pairs used to apply as tags on supported cloud models. | |
snap-http-proxy* | string | “” | The HTTP proxy value to for installing snaps. | |
snap-https-proxy* | string | “” | The snap-centric HTTPS proxy value. See Offline mode strategies. | |
snap-store-assertions | string | “” | The HTTPS proxy value to for installing snaps. | |
snap-store-proxy* | string | “” | The snap store proxy for installing snaps. | |
snap-store-proxy-url | string | “” | The URL for the defined snap store proxy. | |
ssl-hostname-verification | bool | true | Set whether SSL hostname verification is enabled. | |
storage-default-block-source | string | - |
loop or the cloud-specific value |
The default block storage source for the model. |
storage-default-filesystem-source | string | - | any storage provider (Juju will adjust) | The default filesystem storage source for the model. |
transmit-vendor-metrics | bool | true | Determines whether metrics declared by charms deployed into this model are sent for anonymized aggregate analytics. | |
update-status-hook-interval | string | 5m | 30s, 6m, 1hr, etc. | How often to run the charm update-status hook, in human-readable time format (default 5m, range 1-60m). |
Cloud-specific keys
Cloud specific config keys are defined for the following cloud types: ec2, google, oci, and openstack. These config keys can be found by with the show-cloud command using the defined cloud name.
juju show-cloud --include-config aws
