Configuration > List of model configuration keys >
cloudinit-userdata
This document describes the cloudinit-userdata
model configuration key.
Key | Type | Default | Valid values | Purpose |
cloudinit-userdata |
string | “” | Cloud-init user-data (in yaml format) to be added to userdata for new machines created in this model. |
This is a sharp knife feature - be careful with it.
The cloudinit-userdata
allows the user to provide additional cloudinit data to be included in the cloudinit data created by Juju.
Specifying a key will overwrite what juju puts in the cloudinit file with the following caveats:
users
andbootcmd
keys will cause an error - The
packages
key will be appended to the packages listed by juju - The
runcmds
key will cause an error. You can specifypreruncmd
andpostruncmd
keys to prepend and append the runcmd created by Juju.
Use cases
- setting a default locale for deployments that wish to use their own locale settings
- adding custom CA certificates for models that are sitting behind an HTTPS proxy
- adding a private apt mirror to enable private packages to be installed
- add SSH fingerprints to a deny list to prevent them from being printed to the console for security-focused deployments
Background
Juju uses cloud-init to customise instances once they have been provisioned by the cloud. The cloudinit-userdata
model configuration setting (model config) allows you to tweak what happens to machines when they are created up via the “user data” feature.
From the website:
Cloud images are operating system templates and every instance starts out as an identical clone of every other instance. It is the user data that gives every cloud instance its personality and cloud-init is the tool that applies user data to your instances automatically.
Using
Providing custom user data to cloudinit
Create a file, cloudinit-userdata.yaml
, which starts with the cloudinit-userdata
key and data you wish to include in the cloudinit file. Note: juju reads the value as a string, though formatted as YAML.
Template cloudinit-userdata.yaml
cloudinit-userdata: |
<key>: <value>
<key>: <value>
Provide the path your file to the model-config
command:
juju model-config cloudinit-userdata.yaml
Reading the current setting
To read the current value, provide the cloudinit-userdata
key to the model-config
command as a command-line parameter. Adding the --format yaml
option ensures that it is properly formatted.
juju model-config cloudinit-userdata --format yaml
Sample output:
packages:
- 'python-keystoneclient'
- 'python-glanceclient'
Clearing the current custom user data
Use the --reset
option to the model-config
command to clear anything that has been previously set.
juju model-config --reset cloudinit-userdata
Known Issues
- In cloud-init, the
runcmd
key accepts both lists of strings and strings. However, Juju only supports strings currently. This will be resolved when “cloudinit-userdata doesn’t handle lists in rancid properly” is fixed. - custom cloudinit-userdata must be passed via file, not as options on the command line (like the
config
command)
Further reading
Model configuration settings are documented as part of Juju’s official docs:
To read more about how various levels of settings inter-operate in the Juju model, read this post in Discourse:
