Configuration > List of model configuration keys >
disable-network-management
This document describes the disable-network-management model configuration key.
| Key | Type | Default | Valid values | Purpose |
disable-network-management |
bool | false | Whether the provider should control networks (on MAAS models, set to true for MAAS to control networks). |
This key can only be used with MAAS models and should otherwise be set to ‘false’ (default) unless you want to take over network control from Juju because you have unique and well-defined needs. Setting this to ‘true’ with MAAS gives you the same behaviour with containers as you already have with other providers: one machine-local address on a single network interface, bridged to the default bridge.
