Enable tracing
This guide contains the steps to enable tracing with Grafana Tempo for your MySQL Router K8s application.
To summarize:
- Deploy the Tempo charm in a COS K8s environment
- Offer interfaces for cross-model integrations
- Consume and integrate cross-model integrations
- View MySQL Router K8s traces on Grafana
This feature is available for Charmed MySQL Router K8s revision 117+ only.
- Have deployed a Charmed MySQL K8s application
- Have deployed a Charmed MySQL Router K8s application in the same model as the Charmed MySQL application
- Have deployed a ‘cos-lite’ bundle in a Kubernetes environment
Deploy Tempo
Then, deploy the dependencies of Tempo following this tutorial. In particular, we would want to:
- Deploy the minio charm
- Deploy the s3 integrator charm
- Add a bucket in minio using a python script
- Configure s3 integrator with the minio credentials
Finally, deploy and integrate with Tempo HA in a monolithic setup.
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed MySQL Router is deployed.
juju offer <tempo_coordinator_k8s_application_name>:tracing
Then, switch to the Charmed MySQL Router K8s model, find the offers, and integrate (relate) with them:
juju switch <k8s_controller_name>:<mysql_router_k8s_model_name>
Do not miss the “
:” in the command above.
Store URL Access Interfaces
k8s admin/cos.tempo admin tracing:tracing
juju consume k8s:admin/cos.tempo
Offer interfaces
First, deploy Grafana Agent K8s from the 1/stable channel:
juju deploy grafana-agent-k8s --channel 1/stable
Then, integrate Grafana Agent k8s with the consumed interface from the previous section:
juju integrate grafana-agent-k8s:tracing tempo:tracing
Finally, integrate Charmed MySQL Router K8s with Grafana Agent K8s:
juju integrate mysql-router-k8s:tracing grafana-agent-k8s:tracing-provider
Wait until the model settles. The following is an example of the juju status --relations on the Charmed MySQL Router K8s model:
database k8s microk8s/localhost 3.5.4 unsupported 18:32:28Z
SAAS Status Store URL
tempo active k8s admin/cos.tempo
grafana-agent-k8s 0.40.4 active 1 grafana-agent-k8s 1/stable 115 10.152.183.141 no grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
mysql-k8s 8.0.37-0ubuntu0.22.04.3 active 1 mysql-k8s 8.0/edge 201 10.152.183.58 no
mysql-router-k8s 8.0.37-0ubuntu0.22.04.3 active 1 mysql-router-k8s 1 10.152.183.50 no
mysql-test-app 0.0.2 active 1 mysql-test-app latest/stable 51 10.152.183.162 no
grafana-agent-k8s/0* active idle 10.1.241.221 grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
mysql-k8s/0* active idle 10.1.241.213 Primary
mysql-router-k8s/0* active idle 10.1.241.222
mysql-test-app/0* active idle 10.1.241.218
grafana-agent-k8s:peers grafana-agent-k8s:peers grafana_agent_replica peer
grafana-agent-k8s:tracing-provider mysql-router-k8s:tracing tracing regular
mysql-k8s:database mysql-router-k8s:backend-database mysql_client regular
mysql-k8s:database-peers mysql-k8s:database-peers mysql_peers peer
mysql-k8s:restart mysql-k8s:restart rolling_op peer
mysql-k8s:upgrade mysql-k8s:upgrade upgrade peer
mysql-router-k8s:cos mysql-router-k8s:cos cos peer
mysql-router-k8s:database mysql-test-app:database mysql_client regular
mysql-router-k8s:mysql-router-peers mysql-router-k8s:mysql-router-peers mysql_router_peers peer
mysql-router-k8s:upgrade-version-a mysql-router-k8s:upgrade-version-a upgrade peer
mysql-test-app:application-peers mysql-test-app:application-peers application-peers peer
tempo:tracing grafana-agent-k8s:tracing tracing regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore section with tempo-k8s as the data source. You will be able to select mysql-router-k8s as the Service Name under the Search tab to view traces belonging to Charmed MySQL Router K8s.
Below is a screenshot demonstrating a Charmed MySQL Router K8s trace:
Feel free to read through the Tempo HA documentation at your leisure to explore its deployment and its integrations.
