Reference > Release Notes > All revisions > Revision 117
Revision 117
Aug 20, 2024
Dear community,
We’d like to announce that Canonical’s newest Charmed MySQL Router K8s operator has been published in the ‘8.0/stable’ channel ![]()
- New workload version MySQL Router 8.0.36 [PR#209]
- K8s NodePort support [PR#211]
- Observability with COS [PR#210]
- Introduced COS Tracing support [PR#250][DPE-4615]
- Router version displayed in upgrade status [PR#230]
- All the functionality from previous revisions
Bugfixes
- Fix TLS configuration immediately deleted after enabling [PR#249]
- Clear connection pool before relating with COS to avoid TIME_WAIT connections + stabilize exporter tests [PR#245][DPE-3899, DPE-4173]
- Updated charmed-mysql ROCK image to latest version [PR#237]
- Removed redundant upgrade check [PR#234]
- Ported over changes from VM operator related to external connectivity [PR#225]
- Updated
resume-upgradeactionforcedescription [PR#232] - Fixed issue if incompatible upgrade is forced [PR#231]
GitHub Releases provide a detailed list of bugfixes, PRs, and commits for each revision.
Inside the charms
- Charmed MySQL Router K8s ships MySQL Router
8.0.36-0ubuntu0.22.04.1 - CLI mysql-shell version is
8.0.36+dfsg-0ubuntu0.22.04.1~ppa4 - The Prometheus
mysql-router-exporteris5.0.1-0ubuntu0.22.04.1~ppa1 - K8s charms based on our ROCK OCI (resource-revision 53, based on Ubuntu LTS
22.04.4), snap revision103 - Principal charms supports the latest LTS series 22.04 only
Technical notes
- Upgrade (
juju refresh) is possible from revision 69+ - Use this operator together with modern operator Charmed MySQL K8s
- Please check restrictions from previous release notes
Contact us
Charmed MySQL Router K8s is an open source project that warmly welcomes community contributions, suggestions, fixes, and constructive feedback.
