Reference > Release Notes > All revisions > Revision 530/531
Revision 530/531
January 6, 2025
Dear community,
Canonical’s newest Charmed MySQL Router K8s operator has been published in the 8.0/stable channel:
- Revision 531 is built for
amd64on Ubuntu 22.04 LTS - Revision 530 is built for
arm64on Ubuntu 22.04 LTS
Highlights
- Updated MySQL Router to
v8.0.39(PR #308) (DPE-4573) - Add K8s LoadBalancer support via expose-external config option (PR #328) (DPE-5637)
Features and improvements
- Add COS Tracing support using Tempo K8s coordinator (PR #324) (DPE-5312)
- Truncated TLS common name to 64 characters (PR #318)
- Bumped supported juju versions (PR #325) (DPE-5625)
v2.9.50→v2.9.51v3.4.5→v3.6.1
Libraries, testing, and CI
- Switched from tox build wrapper to
charmcraft.yamloverrides (PR #319) - Test against juju 3.6/candidate + upgrade dpw to v23.0.5 (PR #335)
- Run juju 3.6 nightly tests against 3.6/stable (PR #337)
- Run tests on juju 3.6 on a nightly schedule (PR #311) (DPE-4976)
- Update canonical/charming-actions action to v2.6.3 (PR #280)
- Update data-platform-workflows to v23 (PR #326)
- Update dependency canonical/microk8s to v1.31 (PR #316)
- Update dependency cryptography to v43 [SECURITY] (PR #317)
- Update Juju agents (patch) (PR #287)
Requirements and compatibility
- (increased) MySQL version:
v8.0.37→v8.0.39 - (increased) Minimum Juju 2 version:
v2.9.50→v2.9.51 - (increased) Minimum Juju 3 version:
v3.4.5→v3.6.1
See the system requirements for more details about Juju versions and other software and hardware prerequisites.
Packaging
This charm is based on the Charmed MySQL rock image. It packages:
- mysql-router
v8.0.39 - mysql-shell
v8.0.38 - prometheus-mysqlrouter-exporter
v5.0.1
See the /lib/charms directory on GitHub for more details about all supported libraries.
See the metadata.yaml file on GitHub for a full list of supported interfaces.
