Charmed Kafka K8s documentation
Charmed Kafka K8s is an open-source operator that makes it easier to manage Apache Kafka on Kubernetes, with built-in support for enterprise features.
Charmed Kafka K8s is built on top of Juju and reliably simplifies the deployment, scaling, design, and management of Apache Kafka on Kubernetes in production. Additionally, you can use the charm to manage your Kafka clusters with automation capabilities. It also offers replication, TLS, password rotation, easy-to-use application integration, and monitoring. Charmed Kafka K8s operates Apache Kafka on different Kubernetes distributions, featuring support for both on-premise installation (e.g. using MicroK8s) or cloud services (e.g. AWS EKS).
Charmed Kafka K8s is a solution designed and developed for helping ops teams and administrators to automate Apache Kafka operations from Day 0 to Day 2, across multiple cloud environments and platforms.
Canonical has also developed the Charmed Kafka operator to support Kafka in VM/IAAS environments.
Charmed Kafka K8s is developed and supported by Canonical, as part of its commitment to provide open-source, self-driving solutions, seamlessly integrated using the Operator Framework Juju. Please refer to Charmhub.io, for more Charmed operators that can be integrated by Juju.
In this documentation
Tutorials Get started - a hands-on introduction to using Charmed Kafka K8s operator for new users |
Reference Technical information - specifications, APIs, architecture |
Project and community
Charmed Kafka K8s is a distribution of Apache Kafka. It’s an open-source project that welcomes community contributions, suggestions, fixes and constructive feedback.
- Read our Code of Conduct
- Join the Discourse forum
- Contribute and report issues
- Explore Canonical Data Fabric solutions
- Contact us for all further questions
License
The Charmed Kafka K8s Operator is free software, distributed under the Apache Software License, version 2.0. See LICENSE for more information.
Navigation
Level | Path | Navlink |
1 | tutorial | Tutorial |
2 | t-overview | 1. Introduction |
2 | t-setup-environment | 2. Set up the environment |
2 | t-deploy | 3. Deploy Kafka |
2 | t-relate-kafka | 4. Integrate with client applications |
2 | t-manage-passwords | 5. Manage passwords |
2 | t-enable-encryption | 6. Enable Encryption |
2 | t-cleanup-environment | 7. Cleanup your environment |
1 | how-to | How To |
2 | h-deploy | Deploy |
2 | h-manage-units | Manage units |
2 | h-manage-app | Manage applications |
2 | h-enable-encryption | Enable encryption |
2 | h-upgrade | Upgrade |
2 | h-enable-monitoring | Enable Monitoring |
2 | h-integrate-alerts-dashboards | Integrate alerts and dashboards |
2 | h-cluster-migration | Migrate a cluster |
1 | reference | Reference |
2 | r-actions | Actions |
2 | r-configurations | Configurations |
2 | r-libraries | Libraries |
2 | r-file-system-paths | File System Paths |
2 | r-listeners | Kafka Listeners |
2 | r-statuses | Statuses |
2 | r-requirements | Requirements |
2 | r-contacts | Contact |
Redirects
Mapping table
Path | Location |
