Charmed Apache Kafka K8s Documentation - Explanation Security
Cryptography
This document describes cryptography used by Charmed Apache Kafka K8s.
Resource checksums
Every version of the Charmed Apache Kafka K8s and Charmed Apache ZooKeeper K8s operators employs a pinned revision of the Charmed Apache Kafka rock and Charmed Apache ZooKeeper rock, respectively, to provide reproducible and secure environments. The Charmed Apache Kafka rock and Charmed Apache ZooKeeper rock are OCI images derived by the Charmed Apache Kafka snap and Charmed Apache ZooKeeper snap, which package the Apache Kafka and Apache ZooKeeper workload together with a set of dependencies and utilities required by the lifecycle of the operators (see Charmed Apache Kafka snap contents and Charmed Apache ZooKeeper snap contents).
Every artifact bundled into the Charmed Apache Kafka snap and Charmed Apache ZooKeeper snap is verified against their MD5, SHA256 or SHA512 checksum after download. The installation of certified snaps into the rock is ensured by snap primitives that verify their squashfs filesystems images GPG signature. For more information on the snap verification process, refer to the snapcraft.io documentation.
Sources verification
Charmed Apache Kafka sources are stored in:
  • GitHub repositories for snaps, rocks and charms
  • LaunchPad repositories for the Apache Kafka and Apache ZooKeeper upstream fork used for building their respective distributions
LaunchPad
Distributions are built using private repositories only, hosted as part of the SOSS namespace to eventually integrate with Canonical’s standard process for fixing CVEs. Branches associated with releases are mirrored to a public repository, hosted in the Data Platform namespace to also provide the community with the patched source code.
GitHub
All Charmed Apache Kafka and Charmed Apache ZooKeeper artifacts are published and released programmatically using release pipelines implemented via GitHub Actions. Distributions are published as both GitHub and LaunchPad releases via the central-uploader repository, while charms, snaps and rocks are published using the workflows of their respective repositories.
All repositories in GitHub are set up with branch protection rules, requiring:
  • new commits to be merged to main branches via pull request with at least 2 approvals from repository maintainers
  • new commits to be signed (e.g. using GPG keys)
  • developers to sign the Canonical Contributor License Agreement (CLA)
Encryption
The Charmed Apache Kafka operator can be used to deploy a secure Apache Kafka cluster on K8s that provides encryption-in-transit capabilities out of the box for:
  • Interbroker communications
  • Apache ZooKeeper connection
  • External client connection
To set up a secure connection Apache Kafka and Apache ZooKeeper applications need to be integrated with TLS Certificate Provider charms, e.g. self-signed-certificates operator. CSRs are generated for every unit using tls_certificates_interface library that uses cryptography python library to create X.509 compatible certificates. The CSR is signed by the TLS Certificate Provider and returned to the units, and stored in a password-protected Keystore file. The password of the Keystore is stored in Juju secrets starting from revision 168 on Apache Kafka and revision 130 on Apache ZooKeeper. The relation provides also the certificate for the CA to be loaded in a password-protected Truststore file.
When encryption is enabled, hostname verification is turned on for client connections, including inter-broker communication. Cipher suite can be customized by providing a list of allowed cipher suite to be used for external clients and Apache Apache ZooKeeper connections, using the charm config options ssl_cipher_suites and zookeeper_ssl_cipher_suites config options respectively. Please refer to the reference documentation for more information.
Encryption at rest is currently not supported, although it can be provided by the substrate (cloud or on-premises).
Authentication
In the Charmed Apache Kafka solution, authentication layers can be enabled for:
  1. Apache ZooKeeper connections
  2. Apache Kafka inter-broker communication
  3. Apache Kafka Clients
Apache Kafka authentication to Apache ZooKeeper
Authentication to Apache ZooKeeper is based on Simple Authentication and Security Layer (SASL) using digested MD5 hashes of username and password, and implemented both for client-server (with Apache Kafka) and server-server communication. Username and passwords are exchanged using peer relations among Apache ZooKeeper units and using normal relations between Apache Kafka and Apache ZooKeeper. Juju secrets are used for exchanging credentials starting from revision 168 on Apache Kafka and revision 130 on Apache ZooKeeper.
Username and password for the different users are stored in Apache ZooKeeper servers in a JAAS configuration file in plain format. Permission on the file is restricted to the root user.
Apache Kafka Inter-broker authentication
Authentication among brokers is based on SCRAM-SHA-512 protocol. Username and passwords are exchanged via peer relations, using Juju secrets from revision 168 on Charmed Apache Kafka.
Apache Kafka username and password used by brokers to authenticate one another are stored both in a Apache ZooKeeper zNode and in a JAAS configuration file in the Apache Kafka server in plain format. The file needs to be readable and writable by root (as it is created by the charm), and be readable by the snap_daemon user running the Apache Kafka server snap commands.
Client authentication to Apache Kafka
Clients can authenticate to Kafka using:
  1. username and password exchanged using SCRAM-SHA-512 protocols
  2. client certificates or CAs (mTLS)
When using SCRAM, username and passwords are stored in Apache ZooKeeper to be used by the Apache Kafka processes, in peer-relation data to be used by the Apache Kafka charm and in external relation to be shared with client applications. Starting from revision 168 on Charmed Apache Kafka, Juju secrets are used for storing the credentials in place of plain unencrypted text.
When using mTLS, client certificates are loaded into a tls-certificates operator and provided to the Apache Kafka charm via the plain-text unencrypted relation. Certificates are stored in the password-protected Truststore file.
