Charmed Kafka K8s Documentation - Reference Listeners
Kafka Listeners
Charmed Kafka comes with a set of listeners that can be enabled to allow for inter- and intra-cluster communication.
Internal listeners are used for internal traffic and exchange of information between Kafka brokers, whereas external listeners are used for external clients to be optionally enabled based the relations created on particular charm endpoints. Each listener is characterized by a specific port, scope and protocol.
In the following table we summarize the protocols, the port and the relation that each listener is bound to. Nota that based on whether a certificates relation is present, one of two mutually exclusive type of listener can be opened.
Listener name Driving endpoints Protocol Port Scope
SASL_INTERNAL cluster SASL_PLAINTEXT 19092 internal
SASL_INTERNAL cluster + certificates SASL_SSL 19093 internal
SASL_EXTERNAL kafka-client SASL_PLAINTEXT 9092 external
SASL_EXTERNAL kafka-client + certificates SASL_SSL 9093 external
SSL_EXTERNAL trusted-certificate + certificates SSL 9094 external
SSL_EXTERNAL trusted-ca + certificates SSL 9094 external
Note Since cluster is a peer-relation, the SASL_INTERNAL listener is always enabled.
