Charmed Kafka K8s Documentation - How to deploy on AKS
Azure Kubernetes Service (AKS) allows you to quickly deploy a production ready Kubernetes cluster in Azure. To access the AKS Web interface, go to https://portal.azure.com/.
Install Client Environment
Juju
Install Juju via snap:
sudo snap install juju
Check that the Juju version is correctly installed:
juju version
which should show:
3.5.2-genericlinux-amd64
Azure CLI
Follow the user guide for installing the Azure CLI on Linux distributions.
Verify that it is correctly installed running the command below:
az --version
which should show the following output:
azure-cli                         2.65.0
core                              2.65.0
telemetry                          1.1.0
Dependencies:
msal                              1.31.0
azure-mgmt-resource               23.1.1
Python location '/opt/az/bin/python3'
Extensions directory '/home/deusebio/.azure/cliextensions'
Python (Linux) 3.11.8 (main, Sep 25 2024, 11:33:44) [GCC 11.4.0]
Legal docs and information: aka.ms/AzureCliLegal
Your CLI is up-to-date.
Create AKS cluster
Login to your Azure account:
az login
This following examples in this guide will use the single server AKS in location eastus - feel free to change this for your own deployment.
Create a new Azure Resource Group:
az group create --name aks --location eastus
Export the deployment name for further use:
export JUJU_NAME=aks-$USER-$RANDOM
Bootstrap AKS with the following command (increase nodes count/size if necessary):
az aks create -g aks -n ${JUJU_NAME} --enable-managed-identity --node-count 1 --node-vm-size=Standard_D4s_v4 --generate-ssh-keys
Sample output:
  "aadProfile": null,
  "addonProfiles": null,
  "agentPoolProfiles": [
      "availabilityZones": null,
      "capacityReservationGroupId": null,
      "count": 1,
      "creationData": null,
      "currentOrchestratorVersion": "1.28.9",
      "enableAutoScaling": false,
      "enableEncryptionAtHost": false,
      "enableFips": false,
      "enableNodePublicIp": false,
Dump newly bootstrapped AKS credentials:
az aks get-credentials --resource-group aks --name ${JUJU_NAME} --context aks
Sample output:
Merged "aks" as current context in ~/.kube/config
You can verify that the cluster and your client kubectl CLI is correctly configured by running a simple command, such as:
kubectl get pod -A
which should provide the list of the pod services running.
Bootstrap Juju controller on AKS
Bootstrap Juju controller:
juju bootstrap aks <CONTROLLER_NAME>
Sample output:
Creating Juju controller "aks" on aks/eastus
Bootstrap to Kubernetes cluster identified as azure/eastus
Creating k8s resources for controller "controller-aks"
Downloading images
Starting controller pod
Bootstrap agent now started
Contacting Juju controller at 20.231.233.33 to verify accessibility...
Bootstrap complete, controller "aks" is now available in namespace "controller-aks"
Now you can run
	juju add-model <model-name>
to create a new model to deploy k8s workloads.
Deploy Charms
Create a new Juju model, if needed:
juju add-model <MODEL_NAME>
(Optional) Increase the debug level if you are troubleshooting charms:
juju model-config logging-config='<root>=INFO;unit=DEBUG'
Then, Charmed Kafka can be deployed as usual:
juju deploy zookeeper-k8s -n3 --channel 3/stable
juju deploy kafka-k8s -n3 --constraints "instance-type=Standard_A4_v2" --channel 3/stable
juju integrate kafka-k8s zookeeper-k8s
We also recommend to deploy a Data Integrator for creating an admin user to manage the content of the Kafka cluster:
juju deploy data-integrator admin --channel edge \
  --config extra-user-roles=admin \
  --config topic-name=admin-topic
And integrate it with the Kafka application:
juju integrate kafka-k8s admin
For more information on Data Integrator and how to use it, please refer to the how-to manage applications user guide.
Display deployment information
Display information about the current deployments with the following commands:
~$ kubectl cluster-info
Kubernetes control plane is running at https://aks-user-aks-aaaaa-bbbbb.hcp.eastus.azmk8s.io:443
CoreDNS is running at https://aks-user-aks-aaaaa-bbbbb.hcp.eastus.azmk8s.io:443/api/v1/namespaces/kube-system/services/kube-dns:dns/proxy
Metrics-server is running at https://aks-user-aks-aaaaa-bbbbb.hcp.eastus.azmk8s.io:443/api/v1/namespaces/kube-system/services/https:metrics-server:/proxy
~$ az aks list
        "count": 1,
~$ kubectl get node
NAME                                STATUS   ROLES   AGE   VERSION
aks-nodepool1-31246187-vmss000000   Ready    agent   11m   v1.28.9
Clean up
Always clean AKS resources that are no longer necessary - they could be costly!
To clean the AKS cluster, resources and juju cloud, run the following commands:
juju destroy-controller <CONTROLLER_NAME> --destroy-all-models --destroy-storage --force
List all services and then delete those that have an associated EXTERNAL-IP value (load balancers, …):
kubectl get svc --all-namespaces
kubectl delete svc <service-name>
Next, delete the AKS resources (source: Deleting an all Azure VMs)
az aks delete -g aks -n ${JUJU_NAME}
Finally, logout from AKS to clean the local credentials (to avoid forgetting and leaking):
az logout
