This charm is no longer under active development and there will be no further updates. For similar functionality, consider the currently-in-development ‘k8s’ charm.
The Charmed MicroK8s Operator delivers automated operations management from day 0 to day 2 on the MicroK8s Kubernetes Distribution. It is an open source, end-to-end, Kubernetes cluster lifecycle managment on top of Juju.
MicroK8s is an open-source Kubernetes distribution. It provides the functionality of core Kubernetes components, in a small footprint, scalable from a single node to a high-availability production cluster.
By reducing the resource commitments required in order to run Kubernetes, MicroK8s makes it possible to take Kubernetes into new environments, for example:
- turning Kubernetes into a lightweight development tool
- making Kubernetes available for use in minimal environments such as GitHub CI
- adapting Kubernetes for small-appliance IoT applications
Developers use MicroK8s as an inexpensive proving ground for new ideas. In production, ISVs benefit from lower overheads and resource demands and shorter development cycles, enabling them to ship appliances faster than ever.
Project and community
MicroK8s is an open source project that welcomes community contributions, suggestions, fixes and constructive feedback.
In this documentation
| Tutorials Get started - a hands-on introduction to using Charmed MicroK8s for new users |
| Reference Technical information - specifications, APIs, architecture |
Explanation Concepts - discussion and clarification of key topics |
Navigation
Navigation table
| Level | Path | Navlink |
| 1 | tutorial | Tutorial |
| 2 | getting-started | Getting started |
| 1 | how-to | How To |
| 2 | how-to-cluster | Deploy a cluster |
| 2 | how-to-add-k8s | Deploy Kubernetes charms |
| 2 | how-to-configuration | Configure MicroK8s |
| 2 | how-to-traefik-ingress | Set up Traefik Ingress |
| 2 | how-to-upgrade | Upgrade |
| 2 | how-to-cos | Add observability |
| 2 | how-to-advanced-dns | Advanced DNS configuration |
| 2 | how-to-ceph | Use Ceph Storage |
| 1 | reference | Reference |
| 2 | release-notes | Release notes |
| 1 | explanation | Explanation |
| 2 | explain-charmed-microk8s | Charmed MicroK8s |
Redirects
Mapping table
| Path | Location |
