This is in connection to the topic of Using Kubernetes with Juju. See that page for background information.
This tutorial will demonstrate how to install the Charmed Distribution of Kubernetes (CDK) and take advantage of the auto-configuration of Kubernetes dynamic persistent volumes (PVs) for use with Kubernetes-specific charms. This is normally done when your backing cloud has a storage type that is supported natively by Kubernetes. Here, we’ll build our cluster with Juju via the CDK bundle using AWS as a backing cloud. The cluster will then be added, as a cloud, to the Juju client’s local cache, after which a controller will be created to manage it.
The following prerequisites are assumed as a starting point for this tutorial:
- You’re using Ubuntu 18.04 LTS.
- Juju
v.2.6.1is installed. See the Installing Juju page. - A credential for the ‘aws’ cloud has been added to Juju. See the Using Amazon AWS with Juju page.
- Sufficient permissions are assigned to the above credential in order for ‘aws-integrator’ to perform operations (see Permissions Requirements; this tutorial assigns the IAM security policy of ‘AdministratorAccess’).
Installing Kubernetes
Begin by creating a controller. We’ll call it ‘aws’:
juju bootstrap aws aws
We’ll deploy Kubernetes using the ‘canonical-kubernetes’ bundle (CDK), which will give us a decently sized cluster. We’ll add an integrator charm by means of an overlay bundle that we’ll store in file k8s-aws-overlay.yaml:
applications:
aws-integrator:
charm: cs:~containers/aws-integrator
num_units: 1
relations:
- ['aws-integrator', 'kubernetes-master']
- ['aws-integrator', 'kubernetes-worker']
See Overlay bundles for details on overlays.
We can now deploy the cluster:
juju deploy canonical-kubernetes --overlay k8s-aws-overlay.yaml
juju trust aws-integrator
The trust command grants ‘aws-integrator’ access to the credential used in the bootstrap command. This charm acts as a proxy for the Juju machines, acting as Kubernetes nodes, to create and attach dynamic storage volumes in the AWS backing cloud.
When a cluster is not built, but merely added, such as one originating from a public Kubernetes service like Azure’s AKS or Google’s GKE, then an integrator charm is not required. Ready-made clusters have storage built in.
It will take about 20 minutes to arrive at a stable status command output:
default aws aws/us-east-1 2.6-rc2 unsupported 20:07:50Z
aws-integrator 1.16.148 active 1 aws-integrator jujucharms 10 ubuntu
easyrsa 3.0.1 active 1 easyrsa jujucharms 235 ubuntu
etcd 3.2.10 active 3 etcd jujucharms 415 ubuntu
flannel 0.10.0 active 5 flannel jujucharms 404 ubuntu
kubeapi-load-balancer 1.14.0 active 1 kubeapi-load-balancer jujucharms 628 ubuntu exposed
kubernetes-master 1.14.1 active 2 kubernetes-master jujucharms 654 ubuntu
kubernetes-worker 1.14.1 active 3 kubernetes-worker jujucharms 519 ubuntu exposed
aws-integrator/0* active idle 0 52.91.184.172 Ready
easyrsa/0* active idle 1 34.201.167.3 Certificate Authority connected.
etcd/0 active idle 2 52.91.39.43 2379/tcp Healthy with 3 known peers
etcd/1* active idle 3 54.166.185.173 2379/tcp Healthy with 3 known peers
etcd/2 active idle 4 3.94.148.234 2379/tcp Healthy with 3 known peers
kubeapi-load-balancer/0* active idle 5 34.200.233.4 443/tcp Loadbalancer ready.
kubernetes-master/0 active idle 6 107.22.102.161 6443/tcp Kubernetes master running.
flannel/4 active idle 107.22.102.161 Flannel subnet 10.1.64.1/24
kubernetes-master/1* active idle 7 54.197.30.23 6443/tcp Kubernetes master running.
flannel/3 active idle 54.197.30.23 Flannel subnet 10.1.40.1/24
kubernetes-worker/0* active idle 8 3.84.152.194 80/tcp,443/tcp Kubernetes worker running.
flannel/0* active idle 3.84.152.194 Flannel subnet 10.1.51.1/24
kubernetes-worker/1 active idle 9 18.234.242.121 80/tcp,443/tcp Kubernetes worker running.
flannel/1 active idle 18.234.242.121 Flannel subnet 10.1.10.1/24
kubernetes-worker/2 active idle 10 34.229.148.230 80/tcp,443/tcp Kubernetes worker running.
flannel/2 active idle 34.229.148.230 Flannel subnet 10.1.83.1/24
0 started 52.91.184.172 i-06d8c42a33dd53f4c bionic us-east-1a running
1 started 34.201.167.3 i-0ef15a160a8d6aea9 bionic us-east-1b running
2 started 52.91.39.43 i-0e97785dce4afad2e bionic us-east-1a running
3 started 54.166.185.173 i-090c7af5f0b0235b7 bionic us-east-1b running
4 started 3.94.148.234 i-01a65ce6300b5bda7 bionic us-east-1c running
5 started 34.200.233.4 i-099bf4c44cab8200c bionic us-east-1c running
6 started 107.22.102.161 i-0d2a5fbf55a93f94a bionic us-east-1b running
7 started 54.197.30.23 i-05c97ea2ce5a50858 bionic us-east-1a running
8 started 3.84.152.194 i-0e6d4f997e0174e3b bionic us-east-1b running
9 started 18.234.242.121 i-044654e51075296c8 bionic us-east-1c running
10 started 34.229.148.230 i-0144700b2ef3ebf43 bionic us-east-1a running
Adding the cluster to Juju
We’ll now copy over the cluster’s main configuration file and then use the add-k8s command to add the cluster to the Juju client’s list of known clouds. Here, we call the new cloud ‘aws-cluster’:
mkdir ~/.kube
juju scp kubernetes-master/0:config ~/.kube/config
juju add-k8s --local --region=ec2/us-east-1 aws-cluster
The first component of the value of the --region option is “cloud type” (‘ec2’) and its second component is the actual region (‘us-east-1’). The latter was obtained from the output to juju controllers:
Controller Model User Access Cloud/Region Models Nodes HA Version
aws default admin superuser aws/us-east-1 2 12 none 2.6-rc2
The fact that the cluster was added without error indicates that the auto-configuration of storage was successful for both operator storage and workload storage. It would have failed if the --region option was omitted, as the inclusion of a cloud type and a region permits the AWS backing cloud to be queried.
The success of this operation can be confirmed by running juju clouds --local.
Creating a controller
Since the cluster is now known to Juju as a cloud, a controller can be created to manage it. We’ll call it ‘k8s’:
juju bootstrap aws-cluster k8s
Now run the clouds command (within the context of the newly-created controller):
juju clouds
Sample output:
Clouds on controller "k8s":
Cloud Regions Default Type Description
aws-cluster 1 us-east-1 k8s
So the ‘k8s’ controller now manages the cluster that was built with the aid of the ‘aws’ controller. The name ‘aws-cluster’ was chosen (during the first invocation of add-k8s) in order to reflect this in the above output.
Adding a model
In contrast to non-Kubernetes controllers, there is no workload model automatically set up for us as part of the controller-creation process (i.e. model ‘default’). Here, we create one called ‘exciter’:
juju add-model exciter
The output to juju models should look like this:
Controller: k8s
Model Cloud/Region Type Status Access Last connection
controller aws-cluster/us-east-1 kubernetes available admin just now
exciter* aws-cluster kubernetes available admin never connected
Deploying Kubernetes charms
We can now deploy a Kubernetes charm. We’ll choose one that has storage requirements:
juju deploy cs:~juju/mariadb-k8s --storage database=10M
Because dynamic storage was set up automatically when the cluster was added there is no need to specify a storage pool. If we did, the value for the --storage option would have looked like database=<pool-name>,10M.
The output to juju status should soon look like the following:
exciter k8s aws-cluster 2.6-rc2 unsupported 03:23:20Z
App Version Status Scale Charm Store Rev OS Address Notes
mariadb-k8s active 1 mariadb-k8s jujucharms 1 kubernetes 10.152.183.58
mariadb-k8s/0* active idle 10.1.83.7 3306/TCP
We can inspect the workload storage volume in use with the storage command:
juju storage
Output:
Unit Storage id Type Pool Size Status Message
mariadb-k8s/0 database/0 filesystem kubernetes 35MiB attached Successfully provisioned volume pvc-4ac4...c590 using kubernetes.io/aws-ebs
We can see that storage class ‘aws-ebs’ was chosen during the storage auto-configuration process.
The model configuration options that are used to track storage class values corroborate this:
juju model-config | grep -e Attribute -e storage
Output:
Attribute From Value
operator-storage controller aws-ebs
workload-storage controller aws-ebs
Next steps
Consider the following tutorials:
