This is in connection to the topic of Using Kubernetes with Juju. See that page for background information.
This tutorial will demonstrate how to take advantage of the auto-configuration of Kubernetes dynamic persistent volumes (PVs) for use with Kubernetes-specific charms. This is normally done when your backing cloud has a storage type that is supported natively by Kubernetes. Here, we’ll use a GKE-based cluster that, naturally, does. The cluster will be added, as a cloud, to an existing GCE-based controller.
The following prerequisites are assumed as a starting point for this tutorial:
- You’re using Ubuntu 18.04 LTS.
- Juju
v.2.6.0is installed. See the Installing Juju page. - A GKE cluster exists and is available to be added to Juju. See appendix Installing a GKE cluster for assistance in building such a cluster.
- The Google CLI tools are installed local to the Juju client and configured. See Install the Google CLI tools in the above appendix.
- A GCE-based controller exists and is managed by the local Juju client. See the Using Google GCE with Juju page for help.
Adding the cluster to an existing controller
We’ll use the add-k8s command to add the cluster to an existing GCE-based controller called ‘gce’. The --gke option invokes the installed Google CLI tools to allow for communication with the GKE provider (i.e. Google). Here, our existing GKE cluster happens to be called ‘hello-cluster’:
juju add-k8s -c gce --gke hello-cluster
You will be asked to confirm your settings. If the Google CLI tools have been fully configured you shouldn’t need to enter any information. You will simply need to confirm default values by pressing ENTER. A sample session:
Available Accounts
javierlarin72@gmail.com
Select account [javierlarin72@gmail.com]: {ENTER}
Available Projects
juju-239814
juju-gce-1225
Select project [juju-239814]: {ENTER}
Available Clusters
hello-cluster in us-east4
Select cluster [hello-cluster in us-east4]: {ENTER}
The fact that the cluster was added without error indicates that the auto-configuration of storage was successful for both operator storage and workload storage.
The success of this operation can be confirmed by running juju clouds -c gce. Here is the command output:
Clouds on controller "gce":
Cloud Regions Default Type Description
google 18 asia-east1 gce
hello-cluster 1 us-east4 k8s
Adding a model to a multi-cloud controller
We want to create a Kubernetes model. Since the controller now manages two clouds (‘google’ and ‘hello-cluster’) we need to specify which cloud we’re interested in. Here, we create a model called ‘turbo’ for the ‘hello-cluster’ cloud:
juju add-model turbo hello-cluster
The output to juju models should now look like this:
Controller: gce
Model Cloud/Region Type Status Machines Cores Units Access Last connection
controller google/us-east1 gce available 1 4 - admin just now
default google/us-east1 gce available 0 - - admin 2 hours ago
turbo* hello-cluster kubernetes available 0 - 2 admin 3 minutes ago
Deploying Kubernetes charms
We can now deploy a Kubernetes charm. For simplicity, we’ll start with a charm that does not have storage requirements:
juju deploy cs:~juju/gitlab-k8s
Next we add a charm that does have storage requirements:
juju deploy cs:~juju/mariadb-k8s --storage database=10M
Because dynamic storage was set up automatically when the cluster was added there is no need to specify a storage pool. If we did, the value for the --storage option would have looked like database=<pool-name>,10M.
Now we add a relation between the two applications:
juju add-relation gitlab-k8s mariadb-k8s
The output to juju status --relations should eventually stabilise to the following:
turbo gce hello-cluster 2.6-rc2 unsupported 20:08:45Z
App Version Status Scale Charm Store Rev OS Address Notes
gitlab-k8s active 1 gitlab-k8s jujucharms 1 kubernetes 10.7.247.1
mariadb-k8s active 1 mariadb-k8s jujucharms 1 kubernetes 10.7.247.60
gitlab-k8s/0* active idle 10.4.6.6 80/TCP
mariadb-k8s/0* active idle 10.4.1.6 3306/TCP
mariadb-k8s:server gitlab-k8s:mysql mysql regular
Here is one of the created workload storage persistent volumes in use:
juju storage
Output:
Unit Storage id Type Pool Size Status Message
mariadb-k8s/0 database/0 filesystem kubernetes 35MiB attached Successfully provisioned volume pvc-X-X-X-X-X using kubernetes.io/gce-pd
There, we see that storage class gce-pd (GCEPersistentDisk) was chosen during the auto-configuration of storage.
Next steps
Consider the following tutorials:
