Bundles are collections of charms. They represent an entire model, rather than a single application. They’re an example of the declarative devops approach.
From a technical point of view, a bundle is a YAML file.
Creating a bundle
The Bundle reference page provides the structure of a bundle file and defines all available properties. It’s a handy reference if you need to create one from scratch or extend a bundle that you currently have.
There are a few short cuts available to you.
Ask Juju to create one from an existing model
When you have an existing model that you wish to replicate elsewhere, you can ask Juju to create a bundle for you:
To start, make sure that the client is accssing the correct model with juju switch
juju switch <model>
The juju-export
bundle command creates the YAML file
juju export-bundle --filename <model>-<date>.yaml
From an example bundle
The charm store contains hundreds of bundles. Consider downloading the contents of a bundle that is similiar to your own via each bundle’s bundle.yaml
file within the “Files” widget. Once it has been downloaded, you are free to add your own custom functionality.
Inside a bundle
The kubernetes-core
provides a good overview of a bundle file.
description: A minimal two-machine Kubernetes cluster, appropriate for development.
series: bionic
machines:
'0':
constraints: cores=2 mem=4G root-disk=16G
series: bionic
'1':
constraints: cores=4 mem=4G root-disk=16G
series: bionic
applications:
containerd:
annotations:
gui-x: '475'
gui-y: '800'
charm: cs:~containers/containerd-53
resources: {}
easyrsa:
annotations:
gui-x: '90'
gui-y: '420'
charm: cs:~containers/easyrsa-295
num_units: 1
resources:
easyrsa: 5
to:
- lxd:0
etcd:
annotations:
gui-x: '800'
gui-y: '420'
charm: cs:~containers/etcd-485
num_units: 1
options:
channel: 3.3/stable
resources:
core: 0
etcd: 3
snapshot: 0
to:
- '0'
flannel:
annotations:
gui-x: '475'
gui-y: '605'
charm: cs:~containers/flannel-466
resources:
flannel-amd64: 537
flannel-arm64: 534
flannel-s390x: 521
kubernetes-master:
annotations:
gui-x: '800'
gui-y: '850'
charm: cs:~containers/kubernetes-master-788
expose: true
num_units: 1
options:
channel: 1.17/stable
resources:
cdk-addons: 0
core: 0
kube-apiserver: 0
kube-controller-manager: 0
kube-proxy: 0
kube-scheduler: 0
kubectl: 0
to:
- '0'
kubernetes-worker:
annotations:
gui-x: '90'
gui-y: '850'
charm: cs:~containers/kubernetes-worker-623
expose: true
num_units: 1
options:
resources:
cni-amd64: 538
cni-arm64: 529
cni-s390x: 541
core: 0
kube-proxy: 0
kubectl: 0
kubelet: 0
to:
- '1'
relations:
- - kubernetes-master:kube-api-endpoint
- kubernetes-worker:kube-api-endpoint
- - kubernetes-master:kube-control
- kubernetes-worker:kube-control
- - kubernetes-master:certificates
- easyrsa:client
- - kubernetes-master:etcd
- etcd:db
- - kubernetes-worker:certificates
- easyrsa:client
- - etcd:certificates
- easyrsa:client
- - flannel:etcd
- etcd:db
- - flannel:cni
- kubernetes-master:cni
- - flannel:cni
- kubernetes-worker:cni
- - containerd:containerd
- kubernetes-worker:container-runtime
- kubernetes-master:container-runtime
Kubernetes bundles
A Kubernetes bundle differs from a standard bundle in the following ways:
- key ‘bundle’ is given the value of ‘kubernetes’
- key ‘num_units’ is replaced by key ‘scale’
- key ‘to’ is replaced by key ‘placement’
The value of ‘placement’ is a key=value pair and is used as a Kubernetes node selector.
For example:
bundle: kubernetes
applications:
mariadb:
charm: cs:~juju/mariadb-k8s
scale: 2
constraints: mem=1G
options:
dataset-size: 70%
storage:
database: mariadb-pv,20M
gitlab:
charm: cs:~juju/gitlab-k8s
placement: foo=bar
scale: 1
relations:
- - gitlab:mysql
- mariadb:server
Deploying bundles
A bundle is deployed just like a regular charm is:
juju deploy wiki-simple
See the Deploying applications page for details on the deploy
command.
To get a summary of the deployment steps (without actually deploying) a dry run can be performed:
juju deploy --dry-run wiki-simple
The --dry-run
option works only with bundles, not with regular charms.
You can get the name of a bundle from the Juju Charm Store, just as you would a charm. There, you can see icons representing each separate application alongside the bundle’s name. This gives you a quick overview of a bundle’s complexity and potential resource requirements.
To get a bundle’s name, select a bundle on the store and find the ‘command prompt’ icon at the top of the pane. A field will contain the Charm Store URL for the bundle, which you can also use to deploy:
juju deploy cs:bundle/wiki-simple-4
The cs
signifies “charm store”.
Bundles can also be deployed by referring to a local bundle file (if it exists). We’ll see this in the Creating bundles section.
Configuring bundles
Below we present two ways in which existing bundles can be customised for your environment:
- Setting application constraints
- Setting application configuration options
To make a bundle as reusable as possible, it’s common to set minimum constraints for its associated charms, much like you would when deploying charms from the command line. This is done by including a constraints
field to a charm’s definition.
For example, to add memory and CPU constraints to MySQL:
mysql:
charm: "cs:mysql-57"
num_units: 1
constraints: mem=2G cores=4
annotations:
"gui-x": "139"
"gui-y": "168"
Here we show how to co-locate applications along with constrained LXD containers on a single machine:
applications:
wordpress:
charm: "cs:wordpress-5"
num_units: 1
constraints: mem=1G cores=1
annotations:
"gui-x": "339.5"
"gui-y": "-171"
to: lxd:0
mysql:
num_units: 1
constraints: mem=2G cores=2
annotations:
"gui-x": "79.5"
"gui-y": "-142"
to: lxd:0
relations:
- - "wordpress:db"
- "mysql:db"
machines:
"0":
series: xenial
constraints: "arch=amd64 mem=4G cores=4"
Refer to the Using constraints page for in-depth coverage of constraints.
When deploying an application, the charm you use will often support or even require specific configuration options to be set. This is done by including an options
field to the application.
For example, to set the “flavor” of MySQL to ‘percona’:
mysql:
charm: "cs:trusty/mysql-57"
num_units: 1
options:
flavor : percona
annotations:
"gui-x": "139"
"gui-y": "168"
Values for options and annotations can also be read from a file. For binary files, such as binary certificates, there is an option to base64-encode the contents. A file location can be expressed with an absolute or relative (to the bundle file) path. For example:
applications:
my-app:
charm: some-charm
options:
config: include-file://my-config.yaml
cert: include-base64://my-cert.crt
See section Discovering application configuration options to learn about a charm’s options.
Using YAML anchors and aliases
YAML anchors and aliases can be used to stipulate values for certain kinds of objects (usually charm options) in a central place in a bundle file where they can then be referred to elsewhere in the file.
An anchor is a string prefixed with an ampersand (&) and an alias is the same string but prefixed with an asterisk (*). The object’s value is set with the anchor and that value is manifested with the alias. For this to work, anchors must be set before the alias is parsed. For simplicity, just put all the anchors at the very top of the file under an element called variables
. Here is an example:
variables:
openstack-origin: &openstack-origin cloud:bionic-stein
osd-devices: &osd-devices /dev/sdb /dev/vdb
applications:
ceph-osd:
charm: cs:ceph-osd
num_units: 3
options:
osd-devices: *osd-devices
source: *openstack-origin
to:
- '1'
- '2'
- '3'
So in the above excerpt, the options
section would effectively be treated as:
options:
osd-devices: /dev/sdb /dev/vdb
source: cloud:bionic-stein
Creating bundles
Bundles can continue to be modified to the point that you are effectively creating a new bundle. This section presents the following topics:
- Using local charms
- Overlay bundles
- Bundle placement directives
- Machine specifications in a bundle
- Recycling machines
- Binding endpoints within a bundle
- Bundles and charm resources
- Setting up subordinate charms
Using local charms
To integrate a local charm into a bundle a local bundle file, say bundle.yaml
, will be needed and where the charm
field points to the directory of the charm in question. Here is an example:
series: xenial
applications:
mysql:
charm: "/home/ubuntu/charms/mysql"
num_units: 1
The bundle can then be deployed by using the file as the argument instead of a bundle name:
juju deploy ./bundle.yaml
Overlay bundles
Overlay bundles provide you with the ability to customise settings in an upstream bundle for your own needs. For example, you may wish to add extra applications, set custom machine constraints or modify the number of units being deployed. They are especially useful for keeping configuration local, while being able to make use of public bundles.
To add an overlay bundle to a deployment, use the --overlay
option with the juju deploy
command:
juju deploy wiki-simple \
--overlay ~/custom-wiki.yaml
An overlay bundle is just a bundle. That is, it has the same YAML syntax as base bundles.
Some bundle properties (e.g. offers, exposed endpoints) are deployment specific and can only be provided as part of an overlay. For more information please consult the Bundle reference page.
Relative paths
Relative paths are resolved relative to the path of the entity that describes them. That is, relative to the overlay bundle file itself.
Change in behaviour: Before Juju 2.7, relative paths within overlay bundles were resolved relative to the base bundle.
Removing an application from a bundle
An application is removed from the base bundle by defining the application name in the application section, but omitting any values. Removing an application also removes all the relations for that application.
Replacing machines
If a machines section is specified in an overlay bundle it replaces the corresponding section of the base bundle. No merging of machine information is attempted. Multiple overlay bundles can be specified and they are processed in the order they appear on the command line.
Using a single file for bundle and overlay contents
Instead of providing overlays as external files, you may alternatively leverage Juju’s support for multi-document YAML files and provide both the base overlay and any required overlays as a single file.
To do so, the contents of each overlay can be appended after the base bundle contents using the special YAML document separator token ---
as the delimiter. For example:
applications:
mysql:
num_units: 1
to: ["lxd:wordpress/0"]
--- # This is part of overlay 1
applications:
mysql:
num_units: 1
--- # This is part of overlay 2
applications:
mysql:
trust: true
When processing multi-document bundles, Juju will treat the first document as the base bundle and any subsequent document as an overlay.
Further reading
Tutorial Using the aws-integrator charm provides an example of how an “overlay” is used.
You can co-locate applications by using the to
key. When LXD is supported by the backing cloud it is also possible to isolate charms by including the container format in the placement directive.
For example:
mysql:
num_units: 1
annotations:
"gui-x": "139"
"gui-y": "168"
This will install the MySQL application into a LXD container on the same machine as the ‘wordpress/0’ unit.
Alternatively, to install MySQL into a LXD container on machine ‘1’, use the following syntax:
mysql:
num_units: 1
to: ["lxd:1"]
annotations:
"gui-x": "139"
"gui-y": "168"
Bundles may optionally include a machine specification, which allows you to set up specific machines and then to place application units on those machines however you wish. This is done by including a machines
field at the root of the bundle file and then defining machines based on an integer. These machines are objects with three possible fields: series
, constraints
, and annotations
. Finally, these machines are referred to in a charm’s definition by using the placement key to
. For example:
mysql:
num_units: 1
to: 0
annotations:
"gui-x": "139"
"gui-y": "168"
machines:
"0":
series: trusty
constraints: arch=amd64 cores=1 mem=1740 root-disk=8192
This will install the MySQL application on machine ‘0’, which has been assigned a specific series and a collection of constraints.
You may also specify multiple machines for placing multiple units of an application. For example:
mysql:
num_units: 2
to: 0, 1
annotations:
"gui-x": "139"
"gui-y": "168"
machines:
"0":
series: trusty
"1":
series: trusty
constraints: arch=amd64 cores=4 mem=4096 root-disk=8192
This will install one unit of the MySQL application on machine ‘0’ and the other on machine ‘1’.
Recycling machines
To have a bundle use a model’s existing machines, as opposed to creating new machines, the --map-machines=existing
option is used. In addition, to specify particular machines for the mapping, comma-separated values of the form ‘bundle-id=existing-id’ can be passed where the bundle-id and the existing-id refer to top level machine IDs.
For example, consider a bundle whose YAML file is configured with machines 1, 2, 3, and 4, and a model containing machines 1, 2, 3, 4, and 5. The following deployment would use existing machines 1 and 2 for bundle machines 1 and 2 but use existing machine 4 for bundle machine 3 and existing machine 5 for bundle machine 4:
juju deploy some-bundle --map-machines=existing,3=4,4=5
Generally, you can configure more complex networks using Network spaces and deploy charms with a binding, as described in Deploying to spaces. However, the same can also be achieved with a bundle and is done by including a bindings
field to a charm’s definition. For example:
mysql:
num_units: 1
bindings:
shared-db: database
cluster: internal
This is equivalent to:
juju deploy cs:mysql-57 --bind "shared-db=database cluster=internal"
The following connects application endpoints to specific spaces and includes a default space, default-space
, for any interfaces not specified:
juju deploy --bind "default-space db=db-space db-admin=admin-space" mysql
Using a bundle file, the above deploy command can be mirrored with the following:
mysql:
num_units: 1
bindings:
"": default-space
db: db-space
db-admin: admin-space
The ""
key in the bindings
map represents all endpoints and can be used to declare the default space for all endpoints. In the above example, any endpoints that are not explicitly bound will be automatically bound to default-space
Specifying application expose parameters within a bundle
Since Juju 2.9, operators can control the expose parameters (CIDRs and/or spaces that are allowed access to the port ranges opened by exposed applications) for the entire application and/or on a per-endpoint basis.
Application expose parameters can also be specified in bundles. However, as expose parameters are deployment-specific, they can only be provided as part of an overlay. Consider the following multi-document bundle:
applications:
mysql:
num_units: 1
--- # overlay
applications:
mysql:
exposed-endpoints:
expose-to-cidrs:
- 0.0.0.0/0
- ::/0
db-admin:
expose-to-spaces:
- dmz
expose-to-cidrs:
- 192.168.0.0/24
This is equivalent to the following commands:
juju expose mysql --to-cidrs 0.0.0.0/0,::/0
juju expose mysql --endpoints db-admin --to-spaces dmz --to-cidrs 192.168.0.0/24
As a result of the above commands, the mysql application will be exposed and:
- All port ranges opened by the charm for any endpoint except
db-admin
will be reachable by any IP address. - Port ranges opened by the charm for the
db-admin
endpoint will only be reachable by IPs that are part of the192.168.0.0/24
block or belong to a subnet associated with thedmz
space.
When using this particular feature, the bundle must not also contain an expose: true
field or Juju will display an error when attempting to deploy the bundle.
This constraint prevents operators from accidentally exposing all ports for an application when attempting to deploy such a bundle to a pre 2.9 controller as older controllers would honor the expose: true
flag but would not interpret the exposed-endpoints
field.
In addition, 2.9 (and newer) Juju clients will also display an error when attempting to deploy a bundle containing an exposed-endpoints
section to a pre 2.9 controller.
Bundles support charm resources (see Using resources) through the use of the resources
key. Consider the following charm metadata.yaml
file that includes a resource called pictures
summary: "example charm."
description: This is an example charm.
resources:
pictures:
type: file
filename: pictures.zip
description: "This charm needs pictures.zip to operate"
It might be desirable to use a specific resource revision in a bundle:
applications:
example-charm:
charm: "cs:example-charm"
series: trusty
resources:
pictures: 1
So here we specify a revision of ‘1’ from the Charm Store.
The resources
key can also specify a local path to a resource instead:
applications:
example-charm:
series: trusty
resources:
pictures: "./pictures.zip"
Local resources can be useful in network restricted environments where the controller is unable to contact the Charm Store.
Bundles and storage
A bundle can specify the storage directives used to satisfy a charm storage declaration. Exactly the same argument as used with juju deploy
with --storage
are supported.
For a charm with storage declaration in its metadata.yaml
file:
storage:
database:
type: filesystem
logs:
type: filesystem
cache:
type: filesystem
A bundle might look like:
applications:
example-charm:
storage:
database: ebs,10G
logs: rootfs,1G
cache: tmpfs
To set up a subordinate charm simply do not use the placement key to
and do not specify any units with the num_units
key. The vital part with a subordinate is to create the relation between it and the principle charm under the relations
element.
Comparing a bundle to a model
To compare a model’s configuration to that of a bundle the diff-bundle
command is used.
Consider, for example, a model that has the below output to the status
command:
docs lxd localhost/localhost 2.5.0 unsupported 05:22:22Z
haproxy unknown 1 haproxy jujucharms 46 ubuntu
mariadb 10.1.37 active 1 mariadb jujucharms 7 ubuntu
mediawiki 1.19.14 active 1 mediawiki jujucharms 19 ubuntu
haproxy/0* unknown idle 2 10.86.33.28 80/tcp
mariadb/0* active idle 1 10.86.33.192 ready
mediawiki/0* active idle 0 10.86.33.19 80/tcp Ready
0 started 10.86.33.19 juju-dbf96b-0 trusty Running
1 started 10.86.33.192 juju-dbf96b-1 trusty Running
2 started 10.86.33.28 juju-dbf96b-2 bionic Running
haproxy:peer haproxy:peer haproxy-peer peer
mariadb:cluster mariadb:cluster mysql-ha peer
mariadb:db mediawiki:db mysql regular
mediawiki:website haproxy:reverseproxy http regular
Now say we have a bundle file bundle.yaml
with these contents:
applications:
mediawiki:
charm: "cs:mediawiki-5"
num_units: 1
options:
mysql:
charm: "cs:mysql-55"
num_units: 1
options:
"binlog-format": MIXED
"block-size": 5
"dataset-size": "512M"
flavor: distro
"ha-bindiface": eth0
"ha-mcastport": 5411
"max-connections": -1
"preferred-storage-engine": InnoDB
"query-cache-size": -1
"query-cache-type": "OFF"
"rbd-name": mysql1
"tuning-level": safest
vip_cidr: 24
vip_iface: eth0
relations:
- - "mediawiki:db"
- "mysql:db"
Comparison of the currently active model with the bundle can be achieved in this way:
juju diff-bundle bundle.yaml
This produces an output of:
applications:
haproxy:
missing: bundle
mariadb:
missing: bundle
mediawiki:
charm:
bundle: cs:mediawiki-5
model: cs:mediawiki-19
series:
bundle: ""
model: trusty
options:
name:
bundle: Central library
model: null
mysql:
missing: model
machines:
"0":
missing: bundle
"1":
missing: bundle
"2":
missing: bundle
relations:
bundle-additions:
- - mediawiki:db
- mysql:db
model-additions:
- - haproxy:reverseproxy
- mediawiki:website
- - mariadb:db
- mediawiki:db
This informs us of the differences in terms of applications, machines, and relations. For instance, compared to the model, the bundle is missing applications ‘haproxy’ and ‘mariadb’, whereas the model is missing ‘mysql’. Both model and bundle utilise the ‘mediawiki’ application but they differ in terms of configuration. There are also differences being reported in the ‘machines’ and ‘relations’ sections. We’ll now focus on the ‘machines’ section in order to demonstrate other features of the diff-bundle
command.
We can extend the bundle by including a bundle overlay. Consider an overlay bundle file changes.yaml
with these machine related contents:
applications:
mediawiki:
to: 2
mysql:
to: 3
machines:
"2":
series: trusty
"3":
series: trusty
Here, by means of the --overlay
option, we can add this extra information to the comparison, effectively inflating the configuration of the bundle:
juju diff-bundle bundle.yaml --overlay changes.yaml
This changes the ‘machines’ section of the output to:
machines:
"0":
missing: bundle
"1":
missing: bundle
"2":
series:
bundle: trusty
model: bionic
"3":
missing: model
The initial comparison displayed a lack of all three machines in the bundle. By adding machines ‘2’ and ‘3’ in the overlay the output now shows machines ‘0’ and ‘1’ as missing in the bundle, machine ‘2’ differs in configuration, and machine ‘3’ is missing in the model.
As with the deploy
command, there is the ability to map machines in the bundle to those in the model. Below, the addition of --map-machines=2=0,3=1
makes, for the sake of the comparison, bundle machines 2 and 3 become model machines 0 and 1, respectively:
juju diff-bundle bundle.yaml --overlay changes.yaml --map-machines=2=0,3=1
The ‘machines’ section now becomes:
machines:
"2":
missing: bundle
The bundle shows as only missing machine 2 now, which makes sense.
The target bundle can also reside within the online Charm Store. In that case you would simply reference the bundle name, such as ‘wiki-simple’:
juju diff-bundle wiki-simple
Saving a bundle
If you have created your own bundle you will probably want to save it. This is done with the export-bundle
command, which exports a single model configuration.
For example, to export the currently active model into file mymodel.yaml
juju export-bundle --filename mymodel.yaml
If Juju detects that the model uses deployment-specific parameters, it will output a multi-document bundle consisting of a base bundle and an overlay document for the deployment-specific settings. For more information on deployment-specific settings please consult the Bundle reference page.
You can also use the Juju GUI to save a bundle. See Adding bundles with the GUI for instructions.
Once the bundle is saved you can consider these Next steps.
