SDK How-to guides
Step-by-step guides covering key operations and common tasks related to the Juju SDK
Manage Charmcraft
Manage charms
Manage charm resources
Manage charm libraries
Manage charm bundles
Add the following next to “Document your library”?
Document your charm
BTW is the linking to charmhub instead of juju.is/tutorials intentional?
Hi @sed-i! Thanks for your feedback—I’ll make them adjacent. Note 1: I’m not sure that doc should be called “How to document your charm”, because it doesn’t really discuss that; rather, only the mechanics of how to add documentation on Charmhub. Note 2: This is very much work in progress. There’s lots that will be moved around in the days to come. Note 3: Yes, linking to juju.is/tutorials was on purpose, as the idea is to keep all documentation together under juju.is/docs. Of course, the formatting is still for juju.is/tutorials, so that poses a small challenge. I’ll probably create a juju.is/docs copy without that formatting, and then add a note in the tutorials doc to link to that.
