Imagine you have a Flask application backed up by a database such as PostgreSQL and need to deploy it. In a traditional setup, this can be quite a challenge, but with Juju you’ll find yourself deploying, configuring, scaling, integrating, monitoring, etc., your Flask application in no time. Let’s get started!
In this tutorial we will build a rock and Kubernetes charm for a Flask application using the charm SDK, so we can have a Flask application up and running with Juju in about 90 minutes.
rock
An Ubuntu LTS-based OCI compatible container image designed to meet security, stability, and reliability requirements for cloud-native software.
charm
A package consisting of YAML files + Python code that will automate every aspect of an application’s lifecycle so it can be easily orchestrated with Juju.
Juju
An orchestration engine for software operators that enables the deployment, integration and lifecycle management of applications using charms.
What you’ll need:
- A workstation, e.g., a laptop, with amd64 architecture which has sufficient resources to launch a virtual machine with 4 CPUs, 4 GB RAM, and a 50 GB disk
- Note that a workstation with arm64 architecture can complete the majority of this tutorial.
- Familiarity with Linux
What you’ll do:
- Set things up
- Create the Flask application
- Run the Flask application locally
- Pack the Flask application into a rock
- Create the charm
- Deploy the Flask application
- Enable
juju config flask-hello-world greeting=<greeting>
- Integrate with a database
- Expose the app using ingress
- Clean up environment
Set things up
Install Multipass.
See more: Multipass | How to install Multipass
Use Multipass to launch an Ubuntu VM.
There are two tracks you can follow to complete the setup process:
- A fast track approach where one command will set up nearly everything for you.
- A hands-on approach where you will set up everything yourself.
Fast track approach
To fast-track the setup, launch a VM with the name charm-dev
using the charm-dev blueprint:
multipass launch --cpus 4 --disk 50G --memory 4G --name charm-dev charm-dev
This step may take a few minutes to complete (10-15 minutes).
This is because the command downloads, installs, (updates,) and configures a number of packages, and the speed will be affected by network bandwidth (not just your own, but also that of the package sources).
However, once it’s done, you’ll have everything you’ll need.
Once the VM is up, open a shell into it:
multipass shell charm-dev
MicroK8s ingress is required to expose the Flask application. Enable using:
sudo microk8s enable ingress
See more: ingress^
Hands-on approach
For a more hands-on setup, use Multipass to launch an Ubuntu VM with the name charm-dev
from the 22.04 blueprint:
multipass launch --cpus 4 --disk 50G --memory 4G --name charm-dev 22.04
In order to create the rock, you’ll need to install Rockcraft:
sudo snap install rockcraft --classic
LXD
will be required for building the rock. Make sure it is installed and initialised:
sudo snap install lxd
lxd init --auto
In order to create the charm, you’ll need to install Charmcraft:
sudo snap install charmcraft --channel latest/edge --classic
This tutorial requires version 3.0.0
or later of Charmcraft. Check the version of Charmcraft using charmcraft --version
If you have an older version of Charmcraft installed, use sudo snap refresh charmcraft --channel latest/edge
to get the latest edge version of Charmcraft.
MicroK8s is required to deploy the Flask application on Kubernetes. Install MicroK8s:
sudo snap install microk8s --channel 1.31-strict/stable
sudo adduser $USER snap_microk8s
newgrp snap_microk8s
Wait for MicroK8s to be ready using sudo microk8s status --wait-ready
. Several MicroK8s add-ons are required for deployment. The MicroK8s registry is required to host the OCI image of the Flask application and ingress is required to expose the Flask application. Enable all using:
sudo microk8s enable hostpath-storage
sudo microk8s enable registry
See more: ingress^
Juju is required to deploy the Flask application. Install Juju and bootstrap a development controller:
sudo snap install juju --channel 3.5/stable
mkdir -p ~/.local/share
juju bootstrap microk8s dev-controller
Create the tutorial directory
Finally, create a new directory for this tutorial and go inside it:
mkdir flask-hello-world
cd flask-hello-world
Start by creating the “Hello, world” Flask application that will be used for this tutorial.
Create a requirements.txt
file, copy the following text into it and then save it:
Flask
In the same directory, copy and save the following into a text file called app.py
import flask
app = flask.Flask(__name__)
@app.route("/")
def index():
return "Hello, world!\n"
if __name__ == "__main__":
app.run()
Install python3-venv
and create a virtual environment:
sudo apt-get update && sudo apt-get install python3-venv -y
python3 -m venv .venv
source .venv/bin/activate
pip install -r requirements.txt
Now that we have a virtual environment with all the dependencies, let’s run the Flask application to verify that it works:
flask run -p 8000
Test the Flask application by using curl
to send a request to the root endpoint. You may need a new terminal for this; if you are using Multipass use multipass shell charm-dev
to get another terminal:
curl localhost:8000
The Flask application should respond with Hello, world!
. The Flask application looks good, so we can stop for now using Ctrl + c.
First, we’ll need a rockcraft.yaml
file. Rockcraft will automate its creation and tailoring for a Flask application by using the flask-framework
profile:
rockcraft init --profile flask-framework
The rockcraft.yaml
file will automatically be created and set the name based on your working directory. Open the file in a text editor and check that the name
is flask-hello-world
. Ensure that platforms
includes the architecture of your host. For example, if your host uses the ARM architecture, include arm64
in platforms
For this tutorial, we’ll use the name
“flask-hello-world” and assume you are on the amd64
platform. Check the architecture of your system using dpkg --print-architecture
. Choosing a different name or running on a different platform will influence the names of the files generated by Rockcraft.
Pack the rock:
rockcraft pack
Depending on your system and network, this step can take a couple of minutes to finish.
Once Rockcraft has finished packing the Flask rock, you’ll find a new file in your working directory with the .rock
extension:
ls *.rock -l
If you changed the name
or version
in rockcraft.yaml
or are not on an amd64
platform, the name of the .rock
file will be different for you.
The rock needs to be copied to the Microk8s registry so that it can be deployed in the Kubernetes cluster:
rockcraft.skopeo --insecure-policy copy --dest-tls-verify=false \
oci-archive:flask-hello-world_0.1_amd64.rock \
docker://localhost:32000/flask-hello-world:0.1
See more: skopeo^
Create the charm
Create a new directory for the charm and go inside it:
mkdir charm
cd charm
We’ll need a charmcraft.yaml
, requirements.txt
and source code for the charm. The source code contains the logic required to operate the Flask application. Charmcraft will automate the creation of these files by using the flask-framework
profile:
charmcraft init --profile flask-framework --name flask-hello-world
The files will automatically be created in your working directory.
The charm depends on several libraries. Download the libraries and pack the charm:
charmcraft fetch-libs
charmcraft pack
Once Charmcraft has finished packing the charm, you’ll find a new file in your working directory with the .charm
extension:
ls *.charm -l
If you changed the name in charmcraft.yaml or are not on the amd64 platform, the name of the .charm
A Juju model is needed to deploy the application. Let’s create a new model:
juju add-model flask-hello-world
If you are not on a host with the amd64 architecture, you will need to include a constraint to the Juju model to specify your architecture. For example, for the arm64 architecture, use juju set-model-constraints -m flask-hello-world arch=arm64
Now the Flask application can be deployed using Juju:
juju deploy ./flask-hello-world_ubuntu-22.04-amd64.charm \
flask-hello-world --resource \
flask-app-image=localhost:32000/flask-hello-world:0.1
It will take a few minutes to deploy the Flask application. You can monitor the progress using juju status --watch 5s
. Once the status of the App has gone to active
, you can stop watching using ctrl + c.
See more: Command ‘juju status’
The Flask application should now be running. We can monitor the status of the deployment using juju status
which should be similar to the following output:
flask-hello-world dev-controller microk8s/localhost 3.1.8 unsupported 17:04:11+10:00
flask-hello-world active 1 flask-hello-world 0 10.152.183.166 no
flask-hello-world/0* active idle 10.1.87.213
The deployment is finished when the status shows active
Test the deployment using curl
to send a request to the root endpoint. The IP address is the Address listed in the Unit section of the juju status
output (e.g., 10.1.87.213
in the sample output above):
curl 10.1.87.213:8000
The application should respond with Hello, world!
Configure the Flask application
Now let’s customise the greeting using a configuration option. We will expect this configuration option to be available in the Flask app configuration under the keyword GREETING
. Go back out to the root directory of the project using cd ..
and copy the following code into app.py
import flask
app.config.from_prefixed_env()
@app.route("/")
def index():
greeting = app.config.get("GREETING", "Hello, world!")
return f"{greeting}\n"
app.run()
Open rockcraft.yaml
and update the version to 0.2
. Run rockcraft pack
again, then upload the new OCI image to the MicroK8s registry:
oci-archive:flask-hello-world_0.2_amd64.rock \
docker://localhost:32000/flask-hello-world:0.2
Change back into the charm directory using cd charm
. The flask-framework
Charmcraft extension supports adding configurations to charmcraft.yaml
which will be passed as environment variables to the Flask application. Add the following to the end of the charmcraft.yaml
file:
config:
options:
greeting:
description: |
The greeting to be returned by the Flask application.
default: "Hello, world!"
type: string
Configuration options are automatically capitalised and -
are replaced by _
. A FLASK_
prefix will also be added which will let Flask identify which environment variables to include when running app.config.from_prefixed_env()
in app.py
Run charmcraft pack
again. The deployment can now be refreshed to make use of the new code:
juju refresh flask-hello-world \
--path=./flask-hello-world_ubuntu-22.04-amd64.charm \
--resource flask-app-image=localhost:32000/flask-hello-world:0.2
For the refresh command, the --constraints
option is not required if you are not running on an amd64
host as Juju will remember the constraint for the life of the application deployment.
Wait for juju status
to show that the App is active
again. Verify that the new configuration has been added using juju config flask-hello-world | grep -A 6 greeting:
which should show the configuration option.
The grep
command extracts a portion of the configuration to make it easier to check whether the configuration option has been added.
Get the updated IP address shown in the Unit section of juju status
. Using curl 10.1.87.215:8000
shows that the response is still Hello, world!
as expected. The greeting can be changed using Juju:
juju config flask-hello-world greeting='Hi!'
now returns the updated Hi!
greeting.
It might take a short time for the configuration to take effect.
Now let’s keep track of how many visitors your application has received. This will require integration with a database to keep the visitor count. This will require a few changes:
- We will need to create a database migration that creates the
visitors
table - We will need to keep track how many times the root endpoint has been called in the database
- We will need to add a new endpoint to retrieve the number of visitors from the database
The charm created by the flask-framework
extension will execute the migrate.py
script if it exists. This script should ensure that the database is initialised and ready to be used by the application. We will create a migrate.py
file containing this logic.
Go back out to the tutorial root directory using cd ..
. Open the migrate.py
file using a text editor and paste the following code into it:
import os
import psycopg2
DATABASE_URI = os.environ["POSTGRESQL_DB_CONNECT_STRING"]
def migrate():
with psycopg2.connect(DATABASE_URI) as conn, conn.cursor() as cur:
cur.execute("""
CREATE TABLE IF NOT EXISTS visitors (
timestamp TIMESTAMP NOT NULL,
user_agent TEXT NOT NULL
conn.commit()
migrate()
The charm will pass the Database connection string in the POSTGRESQL_DB_CONNECT_STRING
environment variable once postgres has been integrated with the charm.
Open the rockcraft.yaml
file in a text editor and update the version to 0.3
To be able to connect to postgresql from the Flask app the psycopg2-binary
dependency needs to be added in requirements.txt
. The app code also needs to be updated to keep track of the number of visitors and to include a new endpoint to retrieve the number of visitors to the app. Open app.py
in a text editor and replace its contents with the following code:
import datetime
import os
import flask
import psycopg2
@app.route("/")
def index():
user_agent = flask.request.headers.get('User-Agent')
timestamp = datetime.datetime.now()
cur.execute(
"INSERT INTO visitors (timestamp, user_agent) VALUES (%s, %s)",
conn.commit()
@app.route("/visitors")
def visitors():
cur.execute("SELECT COUNT(*) FROM visitors")
total_visitors = cur.fetchone()[0]
return f"{total_visitors}\n"
app.run()
Run rockcraft pack
and upload the newly created rock to the MicroK8s registry:
oci-archive:flask-hello-world_0.3_amd64.rock \
docker://localhost:32000/flask-hello-world:0.3
Go back into the charm directory using cd charm
. The Flask app now requires a database which needs to be declared in the charmcraft.yaml
file. Open charmcraft.yaml
in a text editor and add the following section to the end:
requires:
postgresql:
interface: postgresql_client
optional: false
Pack the charm using charmcraft pack
and refresh the deployment using Juju:
--resource flask-app-image=localhost:32000/flask-hello-world:0.3
Deploy postgresql-k8s
using Juju and integrate it with flask-hello-world
juju deploy postgresql-k8s --trust
juju integrate flask-hello-world postgresql-k8s
again. Get the updated IP address shown in the Unit section of juju status
. Running curl 10.1.87.215:8000
should still return the Hi!
greeting. To check the total visitors, use curl 10.1.87.215:8000/visitors
which should return 1
after the previous request to the root endpoint and should be incremented each time the root endpoint is requested. If we perform another request to curl 10.1.87.215:8000
, curl 10.1.87.215:8000/visitors
will return 2
This step of the tutorial only works for hosts with the amd64
architecture. For other architectures, skip this step.
As a final step, let’s expose the application using ingress. Deploy the nginx-ingress-integrator
charm and integrate it with the Flask app:
juju deploy nginx-ingress-integrator
juju integrate nginx-ingress-integrator flask-hello-world
RBAC is enabled in the charm-dev
Multipass blueprint. You will need to run juju trust nginx-ingress-integrator --scope cluster
if you’re using the charm-dev
blueprint.
The hostname of the app needs to be defined so that it is accessible via the ingress. We will also set the default route to be the root endpoint:
juju config nginx-ingress-integrator \
service-hostname=flask-hello-world path-routes=/
Monitor juju status
until everything has a status of active
. Use curl http://flask-hello-world --resolve flask-hello-world:80:127.0.0.1
to send a request via the ingress. It should still be returning the Hi!
greeting.
The --resolve flask-hello-world:80:127.0.0.1
option to the curl
command is a way of resolving the hostname of the request without setting a DNS record.
We’ve reached the end of this tutorial. We have created a Flask application, deployed it locally, integrated it with a database and exposed it via ingress!
If you’d like to reset your working environment, you can run the following in the root directory for the tutorial:
# exit and delete the virtual environment
deactivate
rm -rf charm .venv __pycache__
# delete all the files created during the tutorial
rm flask-hello-world_0.1_amd64.rock flask-hello-world_0.2_amd64.rock \
flask-hello-world_0.3_amd64.rock rockcraft.yaml app.py \
requirements.txt migrate.py
# Remove the juju model
juju destroy-model flask-hello-world --destroy-storage
If you created an instance using Multipass, you can also clean it up. Start by exiting it:
exit
And then you can proceed with its deletion:
multipass delete charm-dev
multipass purge
Next steps
If you are wondering… | visit… |
“How do I…?” | SDK How-to docs |
“How do I debug?” | Charm debugging tools |
“What is…?” | SDK Reference docs |
“Why…?”, “So what?” | SDK Explanation docs |
Contributors: @econley, @jdkandersson , @tmihoc, @weii-wang
