Tempo Coordinator Charm (part of Charmed Tempo HA)
tempo-coordinator-k8s is a charm that, in conjunction with the tempo-worker-k8s charm, deploys and operates Tempo, a distributed tracing backend by Grafana.
This charm, together with one or multiple worker charms, handles deployment, scaling, configuration, and Day 2 operations specific to Tempo.
This operator is the main entry point to the distributed Tempo deployment. It is responsible for configuring the worker nodes and runs an Nginx instance to provide an unified access point to all incoming traffic.
Important! This charm only works in conjunction with its counterpart, and, when deployed in isolation, is not functional. This documentation only contains charm-specific, and as such relatively low-level documentation. For the solution-level documentation, look at the solution-level Charmed Tempo HA docs.
The charm imposes configurable resource limits on the workload, can be readily integrated with trace providers, and comes with built-in alert rules and dashboards for self-monitoring.
This charm is:
- intended to be used together with the
tempo-worker-k8scharm. - intended to be deployed on top of a COS Lite bundle to extend it with tracing.
In this documentation
| Tutorial Get started - a hands-on introduction for new users deploying the charmed operator. |
| Explanation Concepts - discussion and clarification of key topics |
Reference Technical information - specifications, APIs, architecture |
Project and community
Charmed prometheus is part of the Canonical Observability Stack. It is an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
- Read our Code of conduct
- Join the Discourse community forum
- Join the Matrix community chat
- Contribute on GitHub
Thinking about using the Canonical Observability Stack for your next project? Get in touch!
Navigation
| Level | Path | Navlink |
| 1 | Tutorials | Tutorials |
| 1 | How To | How To |
| 2 | configure-resource-limits | Configure memory and CPU limits for tempo-coordinator |
| 2 | manual-receiver-enable | Manually enable a receiver endpoint |
| 1 | Reference | Reference |
| 1 | Explanation | Explanation |
| 2 | worker-coordinator architecture | The worker-coordinator architecture |
Redirects
Mapping table
| Path | Location |
