OpenStack Exporter
The openstack-exporter charm is a machine charm for openstack-exporter.
OpenStack Exporter is a Prometheus exporter for OpenStack, which uses the OpenStack REST APIs to produce metrics about the OpenStack cloud. This charm deploys OpenStack Exporter, configures it to connect to an OpenStack deployment using Keystone, and provides integration with Canonical Observability Stack (COS) (via grafana-agent). It also includes some Grafana dashboards that use provided metrics.
This can be useful to operators and admins looking for more insights into a Charmed OpenStack cloud.
Getting started
Please check out the tutorial.
Security considerations
The charm requests an admin user from Keystone for use with openstack-exporter. The exporter appears to only support an admin user, as non-admin users are not able to list all the endpoints required for the metrics.
Known issues
Releases up until revision 27 required a temporary custom snap build of the software to be provided as charm resource. This is not necessary for newer revisions.
Upgrading the charm from revision 27 or older to a revision higher than 27 may cause the snap to move a blocked state and require manual intervention. This is intentional. Please see the related how-to.
Glance metrics are currently failing to scrape which can cause false alerts.
Security, Bugs and feature requests
If you find a bug in this application or want to request a specific feature, here are the relevant links:
- Raise issues or feature requests on GitHub.
- Security issues in the openstack-exporter charm can be reported through LaunchPad; please read about how to file.
To chat with the community, join our online chat.
Contributing
Please see the Juju SDK docs for guidelines on enhancements to this charm following best practice guidelines, and CONTRIBUTING.md files in the source repository for developer guidance.
License
openstack-exporter charm is free software, distributed under the Apache Software License, version 2.0. See LICENSE for more information.
Navigation
| Level | Path | Navlink |
| 1 | tutorial | Tutorial |
| 1 | how-to | How to |
| 2 | change-port | Change the port |
| 2 | custom-ssl-ca | Custom SSL CA |
| 2 | enable-cache | Enable the cache |
| 2 | troubleshooting | Troubleshoot issues |
| 2 | transition | Transition o-s-c to openstack-exporter |
| 2 | upgrade-from-27-or-older | Upgrade from revision 27 or older |
| 1 | explanation | Explanation |
| 2 | cache | Metrics caching |
| 2 | security | Security |
| 1 | reference | Reference |
| 2 | resources | Resources |
| 2 | integrations | Integrations |
| 2 | configuration | Configuration |
| 2 | metrics-and-alerts | Metrics and alerts |
| 2 | grafana-dashboards | Grafana dashboards |
