Troubleshooting
Snap service is not running
If the openstack-exporter service crashes, the charm will report that it’s not running:
$ juju status openstack-exporter
openstack-exporter/0* blocked idle 15 10.5.0.233 snap service is not running, please check snap service
grafana-agent/0* active idle 10.5.0.233
To see why it crashed, you can view the logs for the service. This can be done by searching the logs in Grafana:
- Navigate to “Explore”
- Select the Loki datasource.
- Filter by
juju_unitequals the grafana-agent unit deployed with the openstack-exporter charm unit - in this case it’sgrafana-agent/0. - Using the “Line contains” filter, enter
golang-openstack-exporter.service.
Or the logs can be viewed directly on the machine:
juju ssh openstack-exporter/0
# show the last 100 lines using snap
sudo snap logs -n 100 golang-openstack-exporter.service
# or using the systemd journal tool
journalctl -u snap.golang-openstack-exporter.service.service
# or search the syslog
less /var/log/syslog
Common reasons the service could crash include:
- Could not verify the ssl certificate from keystone. In this case, see how to set a custom ssl ca.
- Could not connect to keystone (or other openstack api endpoints). If the OpenStack deployment has multiple network spaces, check that the machine has an ip address on both the oam and internal spaces.
