Also see:
Suppose you have determined that you need to create a new relation interface called my_fancy_database
Suppose that your interface specification has the following data model:
- the requirer app is supposed to forward a list of tables that it wants to be provisioned by the database provider
- the provider app (the database) at that point will reply with an API endpoint and, for each replica, it will provide a separate secret ID to authenticate the requests
These are the steps you need to take in order to register it with charm-relation-interfaces
Clone (a fork of) the charm-relation-interfaces
repo and set up an interface specification folder
git clone https://github.com/canonical/charm-relation-interfaces cd /path/to/charm-relation-interfaces
Make a copy of the template folder
Copy the template folder to a new folder called the same as your interface (with underscores instead of dashes).
cp -r ./interfaces/template ./interfaces/my_fancy_database
At this point you should see this directory structure:
# tree ./interfaces/my_fancy_database
└── v0
├── charms.yaml
├── interface_tests
├── README.md
└── schema.py
2 directories, 3 files
Edit charms.yaml
Add to charms.yaml
the charm that owns the reference implementation of the my_fancy_database
interface. Assuming your my_fancy_database_charm
plays the provider
role in the interface, your charms.yaml
will look like this:
# charms.yaml
providers:
- name: my_fancy_database_charm # same as metadata.yaml's .name
url: https://github.com/your_org/my_fancy_database_operator
Edit schema.py
Edit schema.py
to contain:
# schema.py
from interface_tester.schema_base import DataBagSchema
from pydantic import BaseModel, AnyHttpUrl
class ProviderUnitData(BaseModel):
secret_id: str = Field(
description="Secret ID for the key you need in order to query this unit.",
title="Query key secret ID",
examples=["secret:12312323112313123213"],
class ProviderAppData(BaseModel):
api_endpoint: AnyHttpUrl = Field(
description="URL to the database's endpoint.",
title="Endpoint API address",
examples=["https://example.com/v1/query"],
class ProviderSchema(DataBagSchema):
app: ProviderAppData
unit: ProviderUnitData
class RequirerAppData(BaseModel):
tables: List[str] = Field(
description="Tables that the requirer application needs.",
title="Requested tables.",
examples=[["users", "passwords"]],
class RequirerSchema(DataBagSchema):
app: RequirerAppData
# we can omit `unit` because the requirer makes no use of the unit databags
To verify that things work as they should, you can pip install pytest-interface-tester
and then run interface_tester discover --include my_fancy_database
from the charm-relation-interfaces
root.
You should see:
- my_fancy_database:
- v0:
- provider:
- <no tests>
- schema OK
- charms:
- my_fancy_database_charm (https://github.com/your_org/my_fancy_database_operator) custom_test_setup=no
- requirer:
- <no tests>
- schema OK
- <no charms>
In particular pay attention to schema
. If it says NOT OK
then there is something wrong with the pydantic model.
Edit README.md
Edit the README.md
file to contain:
# `my_fancy_database`
## Overview
This relation interface describes the expected behavior between of any charm claiming to be able to interface with a Fancy Database and the Fancy Database itself.
Other Fancy Database-compatible providers can be used interchangeably as well.
## Usage
Typically, you can use the implementation of this interface from [this charm library](https://github.com/your_org/my_fancy_database_operator/blob/main/lib/charms/my_fancy_database/v0/fancy.py), although charm developers are free to provide alternative libraries as long as they comply with this interface specification.
## Direction
The `my_fancy_database` interface implements a provider/requirer pattern.
The requirer is a charm that wishes to act as a Fancy Database Service consumer, and the provider is a charm exposing a Fancy Database (-compatible API).
/```mermaid
flowchart TD
Requirer -- tables --> Provider
Provider -- endpoint, access_keys --> Requirer
## Behavior
The requirer and the provider must adhere to a certain set of criteria to be considered compatible with the interface.
### Requirer
- Is expected to publish a list of tables in the application databag
### Provide
- Is expected to publish an endpoint URL in the application databag
- Is expected to create and grant a Juju Secret containing the access key for each shard and publish its secret ID in the unit databags.
## Relation Data
See the [\[Pydantic Schema\]](./schema.py)
### Requirer
The requirer publishes a list of tables to be created, as a json-encoded list of strings.
#### Example
\```yaml
application_data: {
"tables": "['users', 'passwords']"
### Provider
The provider publishes an endpoint url and access keys for each shard.
#### Example
application_data: {
"api_endpoint": "https://foo.com/query"
units_data : {
"my_fancy_unit/0": {
"secret_id": "secret:12312321321312312332312323"
"my_fancy_unit/1": {
"secret_id": "secret:45646545645645645646545456"
Add interface tests
This topic is explored in a separate document: How to write interface tests
Open a PR to the charm-relation-interfaces
repo
Finally, open a pull request to the charm-relation-interfaces
repo and drive it to completion, addressing any feedback or concerns that the maintainers may have.
Contributors: @ppasotti
