Charm-relation-interfaces
Also see:
charm-relation-interfaces is a repository containing specifications, databag schemas and interface tests for Juju relation interfaces. In other words, it is the source of truth for data and behavior of providers and requirers of integrations.
The purpose of this project is to provide uniformity in the landscape of all possible integrations and promote charm interoperability.
Juju interfaces are untyped, which means that for juju to think two charms can be integrated all it looks at is whether the interface names of the two endpoints you’re trying to connect are the same string. But it might be that the two charms have different, incompatible implementations of two different integrations that happen to have the same name.
In order to prevent two separate charms from rolling their own integration with the same name, and prevent a sprawl of many subtly different interfaces with similar semantics and similar purposes, we introduced charm-relation-interfaces.
Using charm-relation-interfaces
If you have a charm that provides a service, you should search charm-relation-interfaces (or directly charmhub in the future) and see if it exists already, or perhaps a similar one exists that lacks the semantics you need and can be extended to support it.
Conversely, if the charm you are developing needs some service (a database, an ingress url, an authentication endpoint
) you should search charm-relation-interfaces to see if there is an interface you can use, and to find existing charms that provide it.
There are three actors in play:
  • the owner of the specification of the interface, which also owns the tests that can be used to verify “does charm X ‘really’ support this interface?”. This is the charm-relation-interfaces repo.
  • the owner of the implementation of an interface. In practice, this often is the charm that owns the charm library with the reference implementation for an interface.
  • the interface user: a charm that wants to use the interface (either as requirer or as provider).
The interface user needs the implementation (typically, the provider also happens to be the owner and so it already has the implementation). This is addressed by charmcraft fetch-lib.
The owner of the implementation needs the specification, to help check that the implementation is in fact compliant.
Repository structure
For each interface, the charm-relation-interfaces repository hosts:
  • the specification: a semi-formal definition of what the semantics of the interface is, and what its implementations are expected to do in terms of both the provider and the requirer
  • a list of reference charms: these are the charms that implement this interface, typically, the owner of the charm library providing the original implementation.
  • the schema: pydantic models unambiguously defining the accepted unit and application databag contents for provider and requirer.
  • the interface tests: python tests that can be run to verify that a charm complies with the interface specification.
Charm relation interfaces in Charmhub
In the future, Charmhub will have a searchable collection of integration interfaces. Charmhub will, for all charms using the interface, verify that they implement it correctly (regardless of whether they use the ‘official’ implementation or they roll their own) in order to give the charm a happy checkmark on charmhub.io. In order to do that it will need to fetch the specification (from charm-relation-interfaces) and the charm repo, because we can’t know what implementation they are using: we need the source code.
Contributors: @ppasotti
Not sure if this is worth mentioning now, but may be worth considering:
Something I see currently missing from charm-relation-interfaces, at least for the database interfaces, is specification about mutability of the databags.
For example, most of Data Platform’s database charms are written in a way that expects the requirer to write to the databag once and to never change that data. On the provider side, the data can be changed (or sometimes removed) and the requirer is expected to handle that gracefully
Very true. As it is the schemas are static, we don’t fully capture yet the ‘multi-stage’ or back-and-forth interface chatter. Can somewhat do that with interface tests, but not with schemas.
