Command 'juju models'
The information in this doc is based on Juju version 3.5.5, and may not accurately reflect other versions of Juju.
See also: add-model
Lists models a user can access on a controller.
Options
Flag Default Usage
-B, --no-browser-login false Do not use web browser for authentication
--all false Lists all models, regardless of user accessibility (administrative users only)
-c, --controller Controller to operate in
--exact-time false Use full timestamps
--format tabular Specify output format (json|tabular|yaml)
-o, --output Specify an output file
--user The user to list models for (administrative users only)
--uuid false Display UUID for models
Examples
juju models
juju models --user bob
Details
The models listed here are either models you have created yourself, or models which have been shared with you. Default values for user and controller are, respectively, the current user and the current controller. The active model is denoted by an asterisk.
