The information in this doc is based on Juju version 3.5.6, and may not accurately reflect other versions of Juju.
See also: models, model-defaults, show-cloud, controller-config
Displays or sets configuration values on a model.
Usage
juju model-config [options] [<model-key>[=<value>] ...]
Options
Flag | Default | Usage |
-B , --no-browser-login |
--color |
false | Use ANSI color codes in output |
--file |
path to yaml-formatted configuration file | |
--format |
tabular | Specify output format (json|tabular|yaml) |
--ignore-read-only-fields |
false | Ignore read only fields that might cause errors to be emitted while processing yaml documents |
-m , --model |
--no-color |
false | Disable ANSI color codes in tabular output |
-o , --output |
Specify an output file | |
--reset |
Reset the provided comma delimited keys |
Examples
Print the value of default-base:
juju model-config default-base
Print the model config of model mycontroller:mymodel:
juju model-config -m mycontroller:mymodel
Set the value of ftp-proxy to 10.0.0.1:8000:
juju model-config ftp-proxy=10.0.0.1:8000
Set the model config to key=value pairs defined in a file:
juju model-config --file path/to/file.yaml
Set model config values of a specific model:
juju model-config -m othercontroller:mymodel default-base=ubuntu@22.04 test-mode=false
Reset the values of the provided keys to model defaults:
juju model-config --reset default-base,test-mode
Details
To view all configuration values for the current model, run juju model-config You can target a specific model using the -m flag: juju model-config -m juju model-config -m : By default, the config will be printed in a tabular format. You can instead print it in json or yaml format using the --format flag: juju model-config --format json juju model-config --format yaml
To view the value of a single config key, run juju model-config key To set config values, run juju model-config key1=val1 key2=val2 … You can also reset config keys to their default values: juju model-config --reset key1 juju model-config --reset key1,key2,key3 You may simultaneously set some keys and reset others: juju model-config key1=val1 key2=val2 --reset key3,key4
Config values can be imported from a yaml file using the --file flag: juju model-config --file=path/to/cfg.yaml This allows you to e.g. save a model’s config to a file: juju model-config --format=yaml > cfg.yaml and then import the config later. Note that the output of model-config may include read-only values, which will cause an error when importing later. To prevent the error, use the --ignore-read-only-fields flag: juju model-config --file=cfg.yaml --ignore-read-only-fields
You can also read from stdin using “-”, which allows you to pipe config values
from one model to another:
juju model-config -c c1 --format=yaml
| juju model-config -c c2 --file=- --ignore-read-only-fields
You can simultaneously read config from a yaml file and set config keys
as above. The command-line args will override any values specified in the file.
The default-series key is deprecated in favour of default-base e.g. default-base=ubuntu@22.04.
The following keys are available:
agent-metadata-url:
type: string
description: URL of private stream
agent-stream:
type: string
description: Version of Juju to use for deploy/upgrades.
apt-ftp-proxy:
type: string
description: The APT FTP proxy for the model
apt-http-proxy:
type: string
description: The APT HTTP proxy for the model
apt-https-proxy:
type: string
description: The APT HTTPS proxy for the model
apt-mirror:
type: string
description: The APT mirror for the model
apt-no-proxy:
type: string
description: List of domain addresses not to be proxied for APT (comma-separated)
authorized-keys:
type: string
description: Any authorized SSH public keys for the model, as found in a ~/.ssh/authorized_keys
file
automatically-retry-hooks:
type: bool
description: Determines whether the uniter should automatically retry failed hooks
backup-dir:
type: string
description: Directory used to store the backup working directory
charmhub-url:
type: string
description: The url for CharmHub API calls
cloudinit-userdata:
type: string
description: Cloud-init user-data (in yaml format) to be added to userdata for new
machines created in this model
container-image-metadata-defaults-disabled:
type: bool
description: Whether default simplestreams sources are used for image metadata with
containers.
container-image-metadata-url:
type: string
description: The URL at which the metadata used to locate container OS image ids
is located
container-image-stream:
type: string
description: The simplestreams stream used to identify which image ids to search
when starting a container.
container-inherit-properties:
type: string
description: List of properties to be copied from the host machine to new containers
created in this model (comma-separated)
container-networking-method:
type: string
description: Method of container networking setup - one of fan, provider, local
default-base:
type: string
description: The default base image to use for deploying charms, will act like --base
when deploying charms
default-space:
type: string
description: The default network space used for application endpoints in this model
development:
type: bool
description: Whether the model is in development mode
disable-network-management:
type: bool
description: Whether the provider should control networks (on MAAS models, set to
true for MAAS to control networks
disable-telemetry:
type: bool
description: Disable telemetry reporting of model information
egress-subnets:
type: string
description: Source address(es) for traffic originating from this model
enable-os-refresh-update:
type: bool
description: Whether newly provisioned instances should run their respective OS's
update capability.
enable-os-upgrade:
type: bool
upgrade capability.
extra-info:
type: string
description: Arbitrary user specified string data that is stored against the model.
fan-config:
type: string
description: Configuration for fan networking for this model
firewall-mode:
type: string
description: |-
The mode to use for network firewalling.
'instance' requests the use of an individual firewall per instance.
'global' uses a single firewall for all instances (access
for a network port is enabled to one instance if any instance requires
that port).
'none' requests that no firewalling should be performed
inside the model. It's useful for clouds without support for either
global or per instance security groups.
ftp-proxy:
type: string
description: The FTP proxy value to configure on instances, in the FTP_PROXY environment
variable
http-proxy:
type: string
description: The HTTP proxy value to configure on instances, in the HTTP_PROXY environment
variable
https-proxy:
type: string
description: The HTTPS proxy value to configure on instances, in the HTTPS_PROXY
environment variable
ignore-machine-addresses:
type: bool
description: Whether the machine worker should discover machine addresses on startup
type: bool
description: Whether default simplestreams sources are used for image metadata.
image-metadata-url:
type: string
description: The URL at which the metadata used to locate OS image ids is located
image-stream:
type: string
when starting an instance.
juju-ftp-proxy:
type: string
description: The FTP proxy value to pass to charms in the JUJU_CHARM_FTP_PROXY environment
variable
juju-http-proxy:
type: string
description: The HTTP proxy value to pass to charms in the JUJU_CHARM_HTTP_PROXY
juju-https-proxy:
type: string
description: The HTTPS proxy value to pass to charms in the JUJU_CHARM_HTTPS_PROXY
juju-no-proxy:
type: string
description: List of domain addresses not to be proxied (comma-separated), may contain
CIDRs. Passed to charms in the JUJU_CHARM_NO_PROXY environment variable
logforward-enabled:
type: bool
description: Whether syslog forwarding is enabled.
logging-config:
type: string
description: The configuration string to use when configuring Juju agent logging
(see http://godoc.org/github.com/juju/loggo#ParseConfigurationString for details)
logging-output:
type: string
description: 'The logging output destination: database and/or syslog. (default "")'
lxd-snap-channel:
type: string
description: The channel to use when installing LXD from a snap (cosmic and later)
max-action-results-age:
type: string
description: The maximum age for action entries before they are pruned, in human-readable
time format
max-action-results-size:
type: string
description: The maximum size for the action collection, in human-readable memory
format
max-status-history-age:
type: string
description: The maximum age for status history entries before they are pruned,
in human-readable time format
max-status-history-size:
type: string
description: The maximum size for the status history collection, in human-readable
memory format
mode:
type: string
description: |-
Mode is a comma-separated list which sets the
mode the model should run in. So far only one is implemented
- If 'requires-prompts' is present, clients will ask for confirmation before removing
potentially valuable resources.
(default "")
net-bond-reconfigure-delay:
type: int
description: The amount of time in seconds to sleep between ifdown and ifup when
bridging
no-proxy:
type: string
num-container-provision-workers:
type: int
description: The number of container provisioning workers to use per machine
num-provision-workers:
type: int
description: The number of provisioning workers to use per model
provisioner-harvest-mode:
type: string
description: What to do with unknown machines (default destroyed)
proxy-ssh:
type: bool
description: Whether SSH commands should be proxied through the API server
resource-tags:
type: attrs
description: resource tags
saas-ingress-allow:
type: string
description: |-
Application-offer ingress allowlist is a comma-separated list of
CIDRs specifying what ingress can be applied to offers in this model.
secret-backend:
type: string
description: The name of the secret store backend. (default "auto")
snap-http-proxy:
type: string
description: The HTTP proxy value for installing snaps
snap-https-proxy:
type: string
description: The HTTPS proxy value for installing snaps
snap-store-assertions:
type: string
description: The assertions for the defined snap store proxy
snap-store-proxy:
type: string
description: The snap store proxy for installing snaps
snap-store-proxy-url:
type: string
description: The URL for the defined snap store proxy
ssh-allow:
type: string
description: |-
SSH allowlist is a comma-separated list of CIDRs from
which machines in this model will accept connections to the SSH service.
Currently only the aws & openstack providers support ssh-allow
ssl-hostname-verification:
type: bool
description: Whether SSL hostname verification is enabled (default true)
storage-default-block-source:
type: string
description: The default block storage source for the model
storage-default-filesystem-source:
type: string
description: The default filesystem storage source for the model
syslog-ca-cert:
type: string
description: The certificate of the CA that signed the syslog server certificate,
in PEM format.
syslog-client-cert:
type: string
description: The syslog client certificate in PEM format.
syslog-client-key:
type: string
description: The syslog client key in PEM format.
syslog-host:
type: string
description: The hostname:port of the syslog server.
test-mode:
type: bool
description: |-
Whether the model is intended for testing.
If true, accessing the charm store does not affect statistical
data of the store. (default false)
transmit-vendor-metrics:
type: bool
description: Determines whether metrics declared by charms deployed into this model
are sent for anonymized aggregate analytics
update-status-hook-interval:
type: string
description: How often to run the charm update-status hook, in human-readable time
format (default 5m, range 1-60m)
