The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
See also: controllers, model-config, show-cloud
Displays or sets configuration settings for a controller.
Usage
juju controller-config [options] [<attribute key>[=<value>] ...]
Options
Flag | Default | Usage |
-B , --no-browser-login |
-c , --controller |
Controller to operate in | |
--color |
false | Use ANSI color codes in output |
--file |
path to yaml-formatted configuration file | |
--format |
tabular | Specify output format (json|tabular|yaml) |
--ignore-read-only-fields |
false | Ignore read only fields that might cause errors to be emitted while processing yaml documents |
--no-color |
false | Disable ANSI color codes in tabular output |
-o , --output |
Specify an output file |
Examples
Print all config values for the current controller:
Print the value of “api-port” for the current controller:
juju controller-config api-port
Print all config values for the controller “mycontroller”:
juju controller-config -c mycontroller
Set the “auditing-enabled” and “audit-log-max-backups” keys:
juju controller-config auditing-enabled=true audit-log-max-backups=5
Set the current controller’s config from a yaml file:
juju controller-config --file path/to/file.yaml
Details
To view all configuration values for the current controller, run juju controller-config You can target a specific controller using the -c flag: juju controller-config -c By default, the config will be printed in a tabular format. You can instead print it in json or yaml format using the --format flag: juju controller-config --format json juju controller-config --format yaml
To view the value of a single config key, run juju controller-config key To set config values, run juju controller-config key1=val1 key2=val2 …
Config values can be imported from a yaml file using the --file flag: juju controller-config --file=path/to/cfg.yaml This allows you to e.g. save a controller’s config to a file: juju controller-config --format=yaml > cfg.yaml and then import the config later. Note that the output of controller-config may include read-only values, which will cause an error when importing later. To prevent the error, use the --ignore-read-only-fields flag: juju controller-config --file=cfg.yaml --ignore-read-only-fields
You can also read from stdin using “-”, which allows you to pipe config values
from one controller to another:
juju controller-config -c c1 --format=yaml
| juju controller-config -c c2 --file=- --ignore-read-only-fields
You can simultaneously read config from a yaml file and set config keys
as above. The command-line args will override any values specified in the file.
The following keys are available:
agent-logfile-max-backups:
type: int
description: The number of old agent log files to keep (compressed)
agent-logfile-max-size:
type: string
description: The maximum size of the agent log file
agent-ratelimit-max:
type: int
description: The maximum size of the token bucket used to ratelimit agent connections
agent-ratelimit-rate:
type: string
description: The time taken to add a new token to the ratelimit bucket
api-port-open-delay:
type: string
description: "The duration that the controller will wait \nbetween when the controller
has been deemed to be ready to open \nthe api-port and when the api-port is actually
opened \n(only used when a controller-api-port value is set)."
application-resource-download-limit:
type: int
description: The maximum number of concurrent resources downloads per application
audit-log-capture-args:
type: bool
description: Determines if the audit log contains the arguments passed to API methods
audit-log-exclude-methods:
type: list
description: The list of Facade.Method names that aren't interesting for audit logging
purposes.
audit-log-max-backups:
type: int
description: The number of old audit log files to keep (compressed)
audit-log-max-size:
type: string
description: The maximum size for the current controller audit log file
auditing-enabled:
type: bool
description: Determines if the controller records auditing information
caas-image-repo:
type: string
description: The docker repo to use for the jujud operator and mongo images
controller-api-port:
type: int
description: |-
An optional port that may be set for controllers
that have a very heavy load. If this port is set, this port is used by
the controllers to talk to each other - used for the local API connection
as well as the pubsub forwarders, and the raft workers. If this value is
set, the api-port isn't opened until the controllers have started properly.
controller-name:
type: string
description: The canonical name of the controller
controller-resource-download-limit:
type: int
description: The maximum number of concurrent resources downloads across all the
applications on the controller
features:
type: list
description: A list of runtime changeable features to be updated
juju-ha-space:
type: string
description: The network space within which the MongoDB replica-set should communicate
juju-mgmt-space:
type: string
description: The network space that agents should use to communicate with controllers
max-agent-state-size:
type: int
description: The maximum size (in bytes) of internal state data that agents can
store to the controller
max-charm-state-size:
type: int
description: The maximum size (in bytes) of charm-specific state that units can
max-debug-log-duration:
type: string
description: The maximum duration that a debug-log session is allowed to run
max-prune-txn-batch-size:
type: int
description: (deprecated) The maximum number of transactions evaluated in one go
when pruning
max-prune-txn-passes:
type: int
description: (deprecated) The maximum number of batches processed when pruning
migration-agent-wait-time:
type: string
description: The maximum during model migrations that the migration worker will
wait for agents to report on phases of the migration
model-logfile-max-backups:
type: int
description: The number of old model log files to keep (compressed)
model-logfile-max-size:
type: string
description: The maximum size of the log file written out by the controller on behalf
of workers running for a model
model-logs-size:
type: string
description: The size of the capped collections used to hold the logs for the models
mongo-memory-profile:
type: string
description: Sets mongo memory profile
prune-txn-query-count:
type: int
description: The number of transactions to read in a single query
prune-txn-sleep-time:
type: string
description: The amount of time to sleep between processing each batch query
public-dns-address:
type: string
description: Public DNS address (with port) of the controller.
query-tracing-enabled:
type: bool
description: Enable query tracing for the dqlite driver
query-tracing-threshold:
type: string
description: "The minimum duration of a query for it to be traced. The lower the
\nthreshold, the more queries will be output. A value of 0 means all queries \nwill
be output if tracing is enabled."
