The information in this doc is based on Juju version 3.5.4, and may not accurately reflect other versions of Juju.
See also: models, constraints, set-constraints, set-model-constraints
Displays machine constraints for a model.
Options
Flag | Default | Usage |
-B , --no-browser-login |
--format |
constraints | Specify output format (constraints|json|yaml) |
-m , --model |
-o , --output |
Specify an output file |
Examples
juju model-constraints
juju model-constraints -m mymodel
Details
Shows constraints that have been set on the model with
juju set-model-constraints.
By default, the model is the current model.
Model constraints are combined with constraints set on an application
with juju set-constraints
for commands (such as ‘deploy’) that provision
machines/containers for applications. Where model and application constraints overlap, the
application constraints take precedence.
Constraints for a specific application can be viewed with juju constraints
