From Zero to Hero: Write your first Kubernetes charm > Write a unit test for your charm
See previous: Observe your charm with COS Lite
This document is part of a series, and we recommend you follow it in sequence. However, you can also jump straight in by checking out the code from the previous branches:
git clone https://github.com/canonical/juju-sdk-tutorial-k8s.git
cd juju-sdk-tutorial-k8s
git checkout 07_cos_integration
git checkout -b 08_unit_testing
When you’re writing a charm, you will want to ensure that it will behave reliably as intended.
For example, that the various components – relation data, pebble services, or configuration files – all behave as expected in response to an event.
You can ensure all this by writing a rich battery of units tests. In the context of a charm we recommended using pytest
(but unittest
can also be used) and especially the operator framework’s built-in testing library – ops.testing.Harness
. We will be using the Python testing tool tox
to automate our testing and set up our testing environment.
In this chapter you will write a simple unit test to check that your workload container is initialised correctly.
Contents:
- Prepare your test environment
- Prepare your test directory
- Write your unit test
- Run the test
- Review the final code
Create a file called tox.ini
in your charm project’s root directory and add the following to configure your test environment:
[tox]
no_package = True
skip_missing_interpreters = True
min_version = 4.0.0
env_list = unit
[vars]
src_path = {tox_root}/src
tests_path = {tox_root}/tests
[testenv]
set_env =
PYTHONPATH = {tox_root}/lib:{[vars]src_path}
PYTHONBREAKPOINT=pdb.set_trace
PY_COLORS=1
pass_env =
PYTHONPATH
CHARM_BUILD_DIR
MODEL_SETTINGS
[testenv:unit]
description = Run unit tests
deps =
pytest
cosl
coverage[toml]
-r {tox_root}/requirements.txt
commands =
coverage run --source={[vars]src_path} \
-m pytest \
--tb native \
-v \
-s \
{posargs} \
{[vars]tests_path}/unit
coverage report
Read more:
tox.ini
In your project root, create a tests/unit
directory:
mkdir -p tests/unit
In your tests/unit
directory, create a file called test_charm.py
In this file, do all of the following:
First, add the necessary imports:
import ops
import ops.testing
import pytest
from charm import FastAPIDemoCharm
Then, add a test fixture that sets up the testing harness and makes sure that it will be cleaned up after each test:
@pytest.fixture
def harness():
harness = ops.testing.Harness(FastAPIDemoCharm)
harness.begin()
yield harness
harness.cleanup()
Finally, add a first test case as a function, as below. As you can see, this test case is used to verify that the deployment of the fastapi-service
within the demo-server
container is configured correctly and that the service is started and running as expected when the container is marked as pebble-ready
. It also checks that the unit’s status is set to active without any error messages. Note that we mock some methods of the charm because they do external calls that are not represented in the state of this unit test.
def test_pebble_layer(
monkeypatch: pytest.MonkeyPatch, harness: ops.testing.Harness[FastAPIDemoCharm]
monkeypatch.setattr(FastAPIDemoCharm, 'version', '1.0.0')
# Expected plan after Pebble ready with default config
expected_plan = {
'services': {
'fastapi-service': {
'override': 'replace',
'summary': 'fastapi demo',
'command': 'uvicorn api_demo_server.app:app --host=0.0.0.0 --port=8000',
'startup': 'enabled',
# Since the environment is empty, Layer.to_dict() will not
# include it.
# Simulate the container coming up and emission of pebble-ready event
harness.container_pebble_ready('demo-server')
harness.evaluate_status()
# Get the plan now we've run PebbleReady
updated_plan = harness.get_container_pebble_plan('demo-server').to_dict()
service = harness.model.unit.get_container('demo-server').get_service('fastapi-service')
# Check that we have the plan we expected:
assert updated_plan == expected_plan
# Check the service was started:
assert service.is_running()
# Ensure we set a BlockedStatus with appropriate message:
assert isinstance(harness.model.unit.status, ops.BlockedStatus)
assert 'Waiting for database' in harness.model.unit.status.message
Read more:
ops.testing
Run the test
In your Multipass Ubuntu VM shell, run your unit test as below:
ubuntu@charm-dev:~/fastapi-demo$ tox -e unit
You should get an output similar to the one below:
unit: commands[0]> coverage run --source=/home/ubuntu/fastapi-demo/src -m pytest --tb native -v -s /home/ubuntu/fastapi-demo/tests/unit
=============================================================================================================================================================================== test session starts ===============================================================================================================================================================================
platform linux -- Python 3.10.13, pytest-8.0.2, pluggy-1.4.0 -- /home/ubuntu/fastapi-demo/.tox/unit/bin/python
cachedir: .tox/unit/.pytest_cache
rootdir: /home/ubuntu/fastapi-demo
collected 1 item
tests/unit/test_charm.py::test_pebble_layer PASSED
================================================================================================================================================================================ 1 passed in 0.30s ================================================================================================================================================================================
unit: commands[1]> coverage report
Name Stmts Miss Cover
src/charm.py 118 49 58%
TOTAL 118 49 58%
unit: OK (0.99=setup[0.04]+cmd[0.78,0.16] seconds)
congratulations :) (1.02 seconds)
Congratulations, you have now successfully implemented your first unit test!
As you can see in the output, the current tests cover 58% of the charm code. In a real-life scenario make sure to cover much more!
For the full code see: 08_unit_testing
For a comparative view of the code before and after this doc see: Comparison
See next: Write scenario tests for your charm
Contributors: @abatisse , @acsgn , @benhoyt , @bschimke95, @mylesjp, @pmatulis, @tony-meyer, @tmihoc, @james-garner
