From Zero to Hero: Write your first Kubernetes charm > Open a Kubernetes port in your charm
See previous: Write integration tests for your charm
This document is part of a series, and we recommend you follow it in sequence. However, you can also jump straight in by checking out the code from the previous branches:
git clone https://github.com/canonical/juju-sdk-tutorial-k8s.git
cd juju-sdk-tutorial-k8s
git checkout 10_integration_testing
git checkout -b 11_open_port_k8s_service
A deployed charm should be consistently accessible via a stable URL on a cloud.
However, our charm is currently accessible only at the IP pod address and, if the pod gets recycled, the IP address will change as well.
See earlier chapter: Make your charm configurable
In Kubernetes you can make a service permanently reachable under a stable URL on the cluster by exposing a service port via the ClusterIP
. In Juju 3.1+, you can take advantage of this by using the open-port
feature added to ops
since 2.1.0 with the Unit.set_ports()
method available since 2.7.0.
Read more: ClusterIP
In this part chapter of the tutorial you will extend the existing server-port
configuration option to use Juju open-port
functionality to expose a Kubernetes service port. Building on your experience from the previous testing chapters, you will also write tests to check that the new feature you’ve added works as intended.
Contents:
- Add a Kubernetes service port to your charm
- Test the new feature
- Validate your charm
- Review the final code
In your project root’s existing requirements.txt
file, update the required version of ops
as below:
ops >= 2.7
In your src/charm.py
file, do all of the following:
In the _on_config_changed
method, add a new method:
self._handle_ports()
Then, in the definition of the FastAPIDemoCharm
class, define the method:
def _handle_ports(self):
port = int(self.config["server-port"])
self.unit.set_ports(port)
See more:
ops.Unit.set_ports
Write a unit test
If you’ve skipped straight to this chapter:
Note that it builds on the earlier unit testing chapter. To catch up, see: Write unit tests for your charm.
Let’s write a unit test to verify that the port is opened. For that we will extend our existing
test_pebble_layer
unit test to verify that port is opened. Open tests/unit/test_charm.py
and add the following helper method to the TestCharm
class:
def _assert_port_configuration(self, port_number, expected_status):
# Update the server-port configuration with the specified port number
self.harness.update_config({"server-port": port_number})
# Get the set of opened ports from the juju unit
currently_opened_ports = self.harness.model.unit.opened_ports()
# Extract the port numbers from the opened ports set
port_numbers = {port.port for port in currently_opened_ports}
# Retrieve the updated server port configuration from the charm config
server_port_config = self.harness.model.config.get("server-port")
# Check if the server port is 22 (reserved for SSH)
if port_number == 22:
# Assert that the SSH port is not in the set of opened ports
self.assertNotIn(server_port_config, port_numbers)
else:
# Assert that the specified port is in the set of opened ports
self.assertIn(server_port_config, port_numbers)
# Assert that the unit status matches the expected status
self.assertEqual(self.harness.model.unit.status, expected_status)
Now, at the end of test_pebble_layer
method, add the lines below:
# Check port configuration for SSH (port 22) and assert BlockedStatus
self._assert_port_configuration(22, ops.BlockedStatus('Invalid port number, 22 is reserved for SSH'))
# Check port configuration for a custom port (e.g., 1234) and assert ActiveStatus
self._assert_port_configuration(1234, ops.ActiveStatus())
Time to run the test!
In your Multipass Ubuntu VM shell, run the unit test:
ubuntu@charm-dev:~/fastapi-demo$ tox -re unit
If successful, you should get an output similar to the one below:
$ tox -re unit
unit: remove tox env folder /home/ubuntu/juju-sdk-tutorial-k8s/.tox/unit
unit: install_deps> python -I -m pip install cosl 'coverage[toml]' pytest -r /home/ubuntu/juju-sdk-tutorial-k8s/requirements.txt
unit: commands[0]> coverage run --source=/home/ubuntu/juju-sdk-tutorial-k8s/src -m pytest --tb native -v -s /home/ubuntu/juju-sdk-tutorial-k8s/tests/unit
========================================= test session starts =========================================
platform linux -- Python 3.10.12, pytest-7.4.2, pluggy-1.3.0 -- /home/ubuntu/juju-sdk-tutorial-k8s/.tox/unit/bin/python
cachedir: .tox/unit/.pytest_cache
rootdir: /home/ubuntu/juju-sdk-tutorial-k8s
collected 1 item
tests/unit/test_charm.py::TestCharm::test_pebble_layer PASSED
========================================== 1 passed in 0.21s ==========================================
unit: commands[1]> coverage report
Name Stmts Miss Cover
src/charm.py 122 43 65%
TOTAL 122 43 65%
unit: OK (6.00=setup[5.43]+cmd[0.49,0.09] seconds)
congratulations :) (6.04 seconds)
Write a scenario test
Let’s also write a scenario test!
In tests/scenario/test_charm.py
, update the scenario
import line to include PeerRelation
from scenario import Relation, State, Context, Container, Action, PeerRelation
See also:
PeerRelation (ops-scenario)
Now, in the TestCharm
class, add the test case below:
@unittest.mock.patch("charm.LogProxyConsumer")
@unittest.mock.patch("charm.MetricsEndpointProvider")
@unittest.mock.patch("charm.GrafanaDashboardProvider")
def test_open_port(self, *_):
# use scenario.Context to declare what charm we are testing
ctx = Context(
FastAPIDemoCharm,
meta={
"name": "demo-api-charm",
"containers": {"demo-server": {}},
"peers": {"fastapi-peer": {"interface": "fastapi_demo_peers"}},
"requires": {
"database": {
"interface": "postgresql_client",
config={
"options": {
"server-port": {
"default": 8000,
actions={
"get-db-info": {
"params": {"show-password": {"default": False, "type": "boolean"}}
state_in = State(
leader=True,
relations=[
Relation(
endpoint="database",
interface="postgresql_client",
remote_app_name="postgresql-k8s",
local_unit_data={},
remote_app_data={
"endpoints": "127.0.0.1:5432",
"username": "foo",
"password": "bar",
PeerRelation(
endpoint="fastapi-peer",
peers_data={"unit_stats": {"started_counter": "0"}},
containers=[
Container(name="demo-server", can_connect=True),
state1 = ctx.run("config_changed", state_in)
assert len(state1.opened_ports) == 1
assert state1.opened_ports[0].port == 8000
assert state1.opened_ports[0].protocol == "tcp"
In your Multipass Ubuntu VM shell, run your scenario test as below:
ubuntu@charm-dev:~/fastapi-demo$ tox -re scenario
If successful, this should yield:
scenario: remove tox env folder /home/ubuntu/juju-sdk-tutorial-k8s/.tox/scenario
scenario: install_deps> python -I -m pip install cosl 'coverage[toml]' ops-scenario pytest -r /home/ubuntu/juju-sdk-tutorial-k8s/requirements.txt
scenario: commands[0]> coverage run --source=/home/ubuntu/juju-sdk-tutorial-k8s/src -m pytest --tb native -v -s /home/ubuntu/juju-sdk-tutorial-k8s/tests/scenario
platform linux -- Python 3.10.12, pytest-7.4.2, pluggy-1.3.0 -- /home/ubuntu/juju-sdk-tutorial-k8s/.tox/scenario/bin/python
cachedir: .tox/scenario/.pytest_cache
collected 2 items
tests/scenario/test_charm.py::TestCharm::test_get_db_info_action PASSED
tests/scenario/test_charm.py::TestCharm::test_open_port PASSED
========================================== 2 passed in 0.31s ==========================================
scenario: commands[1]> coverage report
src/charm.py 122 22 82%
TOTAL 122 22 82%
scenario: OK (6.66=setup[5.98]+cmd[0.59,0.09] seconds)
congratulations :) (6.69 seconds)
Write an integration test
In your tests/integration
directory, create a helpers.py
file with the following contents:
import socket
from pytest_operator.plugin import OpsTest
async def get_address(ops_test: OpsTest, app_name, unit_num=0) -> str:
"""Get the address for a the k8s service for an app."""
status = await ops_test.model.get_status()
k8s_service_address = status["applications"][app_name].public_address
return k8s_service_address
def is_port_open(host: str, port: int) -> bool:
"""check if a port is opened in a particular host"""
try:
with socket.create_connection((host, port), timeout=5):
return True # If connection succeeds, the port is open
except (ConnectionRefusedError, TimeoutError):
return False # If connection fails, the port is closed
In your existing tests/integration/test_charm.py
file, import the methods defined in helpers.py
from helpers import is_port_open, get_address
Now add the test case that will cover open ports:
@pytest.mark.abort_on_fail
async def test_open_ports(ops_test: OpsTest):
"""Verify that setting the server-port in charm's config correctly adjust k8s service
Assert blocked status in case of port 22 and active status for others
app = ops_test.model.applications.get("demo-api-charm")
# Get the k8s service address of the app
address = await get_address(ops_test=ops_test, app_name=APP_NAME)
# Validate that initial port is opened
assert is_port_open(address, 8000)
# Set Port to 22 and validate app going to blocked status with port not opened
await app.set_config({"server-port": "22"})
await ops_test.model.wait_for_idle(
apps=[APP_NAME], status="blocked", timeout=1000
assert not is_port_open(address, 22)
# Set Port to 6789 "Dummy port" and validate app going to active status with port opened
await app.set_config({"server-port": "6789"})
apps=[APP_NAME], status="active", timeout=1000
assert is_port_open(address, 6789)
In your Multipass Ubuntu VM shell, run the test as below:
ubuntu@charm-dev:~/fastapi-demo$ tox -re integration
This test will take longer as a new model needs to be created. If successful, it should yield something similar to the output below:
==================================== 3 passed in 234.15s (0:03:54) ====================================
integration: OK (254.77=setup[19.55]+cmd[235.22] seconds)
congratulations :) (254.80 seconds)
Validate your charm
Congratulations, you’ve added a new feature to your charm, and also written tests to ensure that it will work properly. Time to give this feature a test drive!
In your Multipass VM, repack and refresh your charm as below:
ubuntu@charm-dev:~/fastapi-demo$ charmcraft pack
juju refresh \
--path="./demo-api-charm_ubuntu-22.04-amd64.charm" \
demo-api-charm --force-units --resource \
demo-server-image=ghcr.io/canonical/api_demo_server:1.0.0
Watch your charm deployment status change until deployment settles down:
juju status --watch 1s
Use kubectl
to list the available services and verify that demo-api-charm
service exposes the ClusterIP
on the expected port:
$ kubectl get services -n charm-model
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
modeloperator ClusterIP 10.152.183.231 <none> 17071/TCP 34m
demo-api-charm-endpoints ClusterIP None <none> <none> 19m
demo-api-charm ClusterIP 10.152.183.92 <none> 65535/TCP,8000/TCP 19m
postgresql-k8s-endpoints ClusterIP None <none> <none> 18m
postgresql-k8s ClusterIP 10.152.183.162 <none> 5432/TCP,8008/TCP 18m
postgresql-k8s-primary ClusterIP 10.152.183.109 <none> 8008/TCP,5432/TCP 18m
postgresql-k8s-replicas ClusterIP 10.152.183.29 <none> 8008/TCP,5432/TCP 18m
patroni-postgresql-k8s-config ClusterIP None <none> <none> 17m
Finally, curl
the ClusterIP
to verify that the version
endpoint responds on the expected port:
$ curl 10.152.183.92:8000/version
{"version":"1.0.0"}
Congratulations, your service now exposes an external port that is independent of any pod / node restarts!
For the full code see: 11_open_port_k8s_service
For a comparative view of the code before and after this doc see: Comparison
See next: Publish your charm on Charmhub
