Publish your charm on Charmhub
From Zero to Hero: Write your first Kubernetes charm > Pushing your charm to charmhub
See previous: Open a Kubernetes port in your charm
This document is part of a series, and we recommend you follow it in sequence. However, you can also jump straight in by checking out the code from the previous branches:
git clone https://github.com/canonical/juju-sdk-tutorial-k8s.git
cd juju-sdk-tutorial-k8s
git checkout 11_open_port_k8s_service
In this tutorial you’ve done a lot of work, and the result is an increasingly functional charm.
You can enjoy this charm on your own, or pass it around to friends, but why not share it with the whole world?
The Canonical way to share a charm publicly is to publish it on Charmhub. Aside from making your charm more visible, this also means you can deploy it more easily, as Charmhub is the default source for juju deploy. Besides, Charmcraft is there to support you every step of the way.
In this chapter of the tutorial you will use Charmcraft to release your charm on Charmhub.
Contents:
  1. Log in to Charmhub
  2. Register your charm’s name
  3. Upload the charm and its resources
  4. Release the charm
Log in to Charmhub
You will need an Ubuntu SSO account.
If you don’t have one yet, sign up on Cookies required
Logging into Charmhub is typically a simple matter of running charmcraft login . However, here we are within a Multipass VM, so we have to take some extra steps.
On your Multipass VM, run the code below:
ubuntu@charm-dev:~/fastapi-demo$ charmcraft login --export ~/secrets.auth
Once you’ve put in your login information, you should see something similar to the output below:
Opening an authorization web page in your browser.
If it does not open, please open this URL:
 https://api.jujucharms.com/identity/login?did=48d45d919ca2b897a81470dc5e98b1a3e1e0b521b2fbcd2e8dfd414fd0e3fa96
Copy-paste the provided web link into your web browser. Use your Ubuntu SSO to log in.
When you’re done, you should see in your terminal the following:
Login successful. Credentials exported to '~/secrets.auth'.
Now set an environment variable with the new token:
export CHARMCRAFT_AUTH=$(cat ~/secrets.auth)
Well done, you’re now logged in to Charmhub!
On your Multipass VM, generate a random 8-digit hexadecimal hash, then view it in the shell:
random_hash=$(cat /dev/urandom | tr -dc 'a-f0-9' | head -c 8)
echo "Random 8-digit hash: $random_hash"
Naming your charm is usually less random than that; see Charm naming guidelines. However, here we are in a tutorial setting, so you just need to make sure to pick a unique name, any name.
Navigate to the charmcraft.yaml file of your charm and update the name field with the randomly generated name.
Once done, prepare the charm for upload by executing charmcraft pack . This command will create a compressed file with the updated name prefix, as discussed earlier.
Now pass this hash as the name to register for your charm on Charmhub:
$ charmcraft register <your random hash name>
Congrats! You are now the publisher of '<your random hash name>'
You’re all set!
On your Multipass VM, run the code below. (The argument to charmcraft upload is the filepath to the .charm file.)
charmcraft upload <your random hash name>_ubuntu-22.04-amd64.charm
Revision 1 of <your random hash name> created
Every time a new binary is uploaded for a charm, a new revision is created on Charmhub. We can verify its current status easily by running charmcraft revisions <charm-name>.
Now upload the charm’s resource – in your case, the demo-server-image OCI image specified in your charm’s charmcraft.yaml as follows:
First, pull it locally:
docker pull ghcr.io/canonical/api_demo_server:1.0.1
Then, take note of the image digest:
docker images canonical/api_demo_server --digests
This should output something similar to the output below:
REPOSITORY      TAG       DIGEST        IMAGE ID       CREATED        SIZE
canonical/api_demo_server   1.0.1     sha256:9a357381b0c2bef91505960be9c38d6235bfc6647a9282ddb4383fd8d175f929
Finally, upload the image as below, specifying first the charm name, then the image name, then a flag with the image digest:
charmcraft upload-resource <your random hash name> demo-server-image --image=sha256:9a357381b0c2bef91505960be9c38d6235bfc6647a9282ddb4383fd8d175f929
Sample output:
Remote image not found, uploading from local registry
Image uploaded, new remote digest: <your remote digest>
Revision 1 created of resource 'demo-server-image' for charm '<your random hash name>'
All set!
Release the charm
Release your charm as below.
Do not worry:
While releasing a charm to Charmhub gives it a public URL, the charm will not appear in the Charmhub search results until it has passed formal review – see Requirements for public listing.
$ charmcraft release <your random hash name> --revision=1 --channel=beta --resource=demo-server-image:1
Revision 1 of charm '<your random hash name>` released to beta
This releases it into a channel so it can become available for downloading.
Just in case, also check your charm’s status:
$ charmcraft status <your random hash name>
Track    Channel    Version    Revision
latest   stable     -          -
         candidate  -          -
         beta       0.1        1
         edge       ↑          ↑
Congratulations, your charm has now been published to charmhub.io!
You can view it at any time at charmhub.io/<your random hash name>.
Contributors: @abatisse, @ibraaoad, @mylesjp , @tmihoc
@tmihoc please assist with the login section with the way that was proposed in the past
is there a way to push an image straight from the upstream without downloading it ?
Not according to Charmcraft source code, when image isn’t within the canonical registry it always tries to get from user’s local registry
As of Charmcraft 2.5 the charm information is in charmcraft.yaml rather than metadata.yaml so the following references should be updated:
Navigate to the metadata.yaml file of your charm and update the name field with the randomly generated name.
Now upload the charm’s resource – in your case, the demo-server-image OCI image specified in your charm’s metadata.yaml as follows:
