Metadata
| Key | Value |
| Summary | Using the Grafana Agent Machine Charm |
| Categories | integrations |
| Difficulty | 3 |
| Author | Jose Massón |
- Preview
- About Grafana Agent machine charm
- Step 0: Understanding the desired situation
- Step 1: Make sure COS Lite is up and running.
- Step 2: Instrument Grafana Agent in our Application’s Charmed Operator
- Step 3: Deploy Zookeeper and Grafana Agent in our VM Juju model.
- Step 4: Relate Grafana Agent to COS-Lite (Prometheus, Loki and Grafana)
- Step 5: Verify that metrics and logs reach Prometheus and Loki
Preview
Initial situation
Let’s assume we have an application that:
- Is running in a virtual machine or in a regular machine.
- Is managed with Juju by its own charm.
- Needs to be observed (monitored).
Desired situation
We would like to collect telemetry from the charmed application into COS Lite, but COS Lite runs in Kubernetes and the application in a machine.
So the question arises: How can we connect both worlds? The answer is simple: use this Grafana Agent machine charm!
The Grafana Agent machine charm
The Grafana Agent machine charm handles installation, configuration, and Day 2 operations specific to Grafana Agent, using Juju and the Charmed Operator Lifecycle Manager (OLM).
This charm was designed to run in virtual machines as a subordinate. Application units are typically run in an isolated container on a machine with no knowledge or access to other applications deployed onto the same machine. With subordinate charms, units of different applications to be deployed into the same container and to have knowledge of each other. Subordinate units scale together with their principal.
As we said before, we are going to use COS Lite to monitor our application, and Grafana Agent machine charm to send application’s telemetry (metris, logs and dashboards)
For that we will have two Juju models:
applications, on a lxd controller, for our application and grafana agentcos, on a k8s controller, for COS Lite
We have to make sure that the observability stack is up and running in our cos model (follow the instructions in COS Lite) in a K8s controller, like this:
Note that COS Lite is offering several interfaces so we can create cross-model relations with applications that are running in different controllers/models:
Offer Application Charm Rev Connected Endpoint Interface Role
alertmanager-karma-dashboard alertmanager alertmanager-k8s 73 0/0 karma-dashboard karma_dashboard provider
grafana-dashboards grafana grafana-k8s 80 0/0 grafana-dashboard grafana_dashboard requirer
loki-logging loki loki-k8s 87 0/0 logging loki_push_api provider
prometheus-receive-remote-write prometheus prometheus-k8s 125 0/0 receive-remote-write prometheus_remote_write provider
prometheus-scrape prometheus prometheus-k8s 125 0/0 metrics-endpoint prometheus_scrape requirer
In this example we use COS Lite to observe Zookeeper.
In order to instrument it, we will have to:
Obtain
cos_agentlib fromgrafana-agentcharm:charmcraft fetch-lib charms.grafana_agent.v0.cos_agent -
Modify only 2 files in your machine charm code:
metadata.yaml,src/charm.py.In
metadata.yamlwe need to add toprovidessection:cos-agent: interface: cos_agentIn
src/charm.pywe import the library:from charms.grafana_agent.v0.cos_agent import COSAgentProviderand instantiate
COSAgentProviderobject in__init__method. For zookeeper it may look like this:self._grafana_agent = COSAgentProvider( self, metrics_endpoints=[ {"path": "/metrics", "port": NODE_EXPORTER_PORT}, {"path": "/metrics", "port": JMX_PORT}, {"path": "/metrics", "port": METRICS_PROVIDER_PORT}, ], metrics_rules_dir="./src/alert_rules/prometheus", logs_rules_dir="./src/alert_rules/loki", dashboard_dirs=["./src/grafana_dashboards"], log_slots=["charmed-zookeeper:logs"], )Note that you can specify the paths where metrics and logs alert rules and dashboards files are stored. In order to know how alert rules and dashboards are written, check these examples.
Re-pack the charm:
charmcraft pack
and voilà!
In order to deploy these applications make sure you already have a VM Juju controller bootstrapped.
In this controller we will create a new model named for instance applications
and deploy (and relate) zookeeper and grafana-agent.
Create the model:
$ juju add-model applications Added 'applications' model on localhost/localhost with credential 'localhost' for user 'admin' -
Deploy Zookeeper using the previous packed
*.charmfile:$ pwd /home/ubuntu/repos/zookeeper-operator $ juju deploy ./*.charm zookeeper Located local charm "zookeeper", revision 0 Deploying "zookeeper" from local charm "zookeeper", revision 0 on jammy -
Deploy Grafana Agent machine charm
juju deploy grafana-agent --channel edgeAfter running these commands the status of the model will be active/idle for both units:
At this point we have one
zookeeperunit inactivestate, and there is nografana-agentunits. This is becausegrafana-agentis a subordinate application. -
Relate
zookeepertografana-agentover thecos-agentrelation:juju relate zookeeper:cos-agent grafana-agentOnce the relation is established, and
grafana-agentis deployed insidezookeeperunit, the status of the model will be:Note that despite of the fact at this point
grafana-agentis collecting telemetry data fromzookeeperit is not forwarding them to the COS Lite deployment we have in the K8s controller.
Since Grafana Agent is meant to send telemetry to COS-Lite, the next step is to relate Grafana Agent to the COS Lite components: Prometheus, Loki and Grafana. This charm need these three relations.
From the model our application is running, we can verify the offers COS Lite is exposing:
$ juju find-offers -m microk8s:cos
Store URL Access Interfaces
microk8s admin/cos.loki-logging admin loki_push_api:logging
microk8s admin/cos.prometheus-receive-remote-write admin prometheus_remote_write:receive-remote-write
microk8s admin/cos.prometheus-scrape admin prometheus_scrape:metrics-endpoint
microk8s admin/cos.alertmanager-karma-dashboard admin karma_dashboard:karma-dashboard
microk8s admin/cos.grafana-dashboards admin grafana_dashboard:grafana-dashboard
As we said before, we will use only three of these offers:
- Prometheus:
admin/cos.prometheus-receive-remote-write - Loki:
admin/cos.loki-logging - Grafana:
The first step to use these offers is to consume them:
$ juju consume microk8s:admin/cos.prometheus-receive-remote-write
Added microk8s:admin/cos.prometheus-receive-remote-write as prometheus-receive-remote-write
$ juju consume microk8s:admin/cos.loki-logging
Added microk8s:admin/cos.loki-logging as loki-logging
$ juju consume microk8s:admin/cos.grafana-dashboards
Added microk8s:admin/cos.grafana-dashboards as grafana-dashboards
Once these commands are executed, the status of our model will change slightly:
Note that in the status we now have a new section named SAAS. In that section we can see all the interfaces offered by other applications running in other models that we can integrate to.
So now let’s relate Grafana Agent with these 3 applications:
juju relate grafana-agent prometheus-receive-remote-write
juju relate grafana-agent loki-logging
juju relate grafana-agent grafana-dashboards
And the three new relations are established, see the relations sections of the model status:
Note that because of this bug you can’t create a new offer after relating an existing one. So first create all offers you intend to consume, and then relate all endpoints. Otherwise juju will complain with: ERROR cannot update application offer "<app>": application endpoint "<endpoint>" has active consumers
Now that the Cross Model Relations are established between our application model and our Observability model, we can easily verify that the metrics zookeeper exposes reaches Prometheus:
$ curl -s http://192.168.122.10/cos-prometheus-0/api/v1/query\?query\=zookeeper_DataDirSize | jq
"status": "success",
"data": {
"resultType": "vector",
"result": [
"metric": {
"__name__": "zookeeper_DataDirSize",
"instance": "applications_f201dfb6-896c-4d5e-83c0-55e6bb8b08f3_zookeeper_zookeeper/0",
"job": "zookeeper_1",
"juju_application": "zookeeper",
"juju_model": "applications",
"juju_model_uuid": "f201dfb6-896c-4d5e-83c0-55e6bb8b08f3",
"juju_unit": "zookeeper/0",
"memberType": "Leader",
"replicaId": "1"
"value": [
1678971938.463,
"67108880"
We can also check that the logs are being sent to Loki, in this case using Grafana:
And finally, we can verify the dashboards Zookeepers provides:
