Testing > Integration testing > Test
includes
In Juju, test includes are special bash util functions designed to help in creating effective integration test suites for juju. This document gives the complete list (STILL UNDER CONSTRUCTION) along with quick descriptions.
check |
Various check functions that help to analyse the output of cli commands and define if test passed or not. Most commonly used: check_contains, check, check_gt. |
cleanup |
Functions that clean up after test is complete. | |
colors |
Colorize the output if the terminal supports doing this. | |
date |
Add date to test output. | |
expect-that |
The ability to work with interactive commands with expect tool. | |
juju |
Functions that allow to operate with juju bootstrap, models, controllers. E.g., ensure, bootstrap, … |
destroy-model |
Takes a model name and destroys the model. | |
ensure |
Ensures that there is a bootstrapped controller with model <model name>. |
random |
Generated random string. | |
run |
Run a command and immediately terminate the script when any error occurs. | |
storage |
Functions which help to test the storages. | |
verbose |
Define the level of verbosity. There are three levels of verbosity. Both 1 and 2 will fail on any error – the difference is that 2 will also turn on juju debug statements, though not shell debug statements. |
