See also: Integration testing
This document demonstrates how to write an integration test for juju.
First, navigate to juju/tests/suites at main · juju/juju · GitHub.
In this directory, create a subdirectory named after the integration test suite you want to use. Let’s call ours example_integration_test_suite.
In your test suite directory, create a file called task.sh. This file typically includes a skip block, a line where you set verbosity, a block where you check dependencies, then a bootstrapping block, a test-listing block, and a tear-down block. An example is given below. Note: The various blocks are created using multiple test includes (e.g., destroy-controller).
test_examples() {
if [ "$(skip 'test_examples')" ]; then
echo "==> TEST SKIPPED: example tests"
return
fi
set_verbosity
echo "==> Checking for dependencies"
check_dependencies juju
file="${TEST_DIR}/test-example.log"
bootstrap "test-example" "${file}"
# Test that need to be run are added here!
test_example
test_other
destroy_controller "test-example"
Also in your test suite directory, create a <test name>.sh file for every integration test you want to write. For example, we’ll create one called example_integration_test, with contents as below. This file consists of a series of subtests (below, run_example1 and run_example2) and a main function (below, test_example), which is the entrypoint to your integration test and which contains some standard logic and also runs the subtests.
run_example1() {
# Echo out to ensure nice output to the test suite.
echo
# The following ensures that a bootstrap juju exists
file="${TEST_DIR}/test-example1.log"
ensure "example1" "${file}"
# Run your checks here
echo "Hello example 1!" | check "Hello example 1!"
# Clean up!
destroy_model "example1"
run_example2() {
echo
file="${TEST_DIR}/test-example2.log"
ensure "example2" "${file}"
echo "Hello example 2!" | check "Hello example 2!"
destroy_model "example2"
test_example() {
if [ -n "$(skip 'test_example')" ]; then
echo "==> SKIP: Asked to skip example tests"
return
fi
set_verbosity
cd .. || exit
run "run_example1"
run "run_example2"
When you are done with your test file, navigate to juju/tests at main · juju/juju · GitHub, open the main.sh file (which is the entrypoint to your integration testing overall) and add your test suite name to the TEST_NAMES variable.
Finally, run your integration test, following the instructions at juju/tests at main · juju/juju · GitHub . Essentially, what you need to do is as below:
./main.sh [<suite_name> [<test_name>]]
