Testing > Integration testing
See also: How to write a integration test
Integration testing juju currently relies on a series of custom-made bash scripts. All these scripts live in juju/tests at main · juju/juju · GitHub . This directory includes two subdirectories, one containing integration test suites and the other test includes. Both are tools that can help you create integration tests.
A typical integration testing package consists of:
- A
<suite name>directory in the /tests/suites directory. - Inside this directory, a main script for the integration test suite,
task.sh. This is the entrypoint to your integration test suite. - In the same directory, a separate
<test name>.shfile for every test. - The juju/tests/main.sh at main · juju/juju · GitHub , which is the entrypoint to your integration testing. This file contains a
TEST_NAMESvariable, which contains the names of all your integration test suites. Whenever you develop a new integration test suites, you need to add its name to this variable.
See more:
