Tempo Worker Charm (part of Charmed Tempo HA)
tempo-worker-k8s is a charm that, in conjunction with the tempo-coordinator-k8s charm, deploys and operates Tempo, a distributed tracing backend by Grafana.
This charm, together with a coordinator application, handles deployment, scaling, configuration, and Day 2 operations specific to Tempo.
This operator is responsible for running and operating a single instance of the main tempo process. It is responsible for applying the configuration generated by the coordinator and monitor the status of the process.
A tempo-worker-k8s application will coordinate with other worker applications, mediated by their shared connection to a tempo-coordinator-k8s instance, to run a Tempo cluster.
Important! This charm only works in conjunction with its counterpart, and, when deployed in isolation, is not functional. This documentation only contains charm-specific, and as such relatively low-level documentation. For the solution-level documentation, look at the solution-level Charmed Tempo HA docs.
This charm is:
- intended to be used together with the
tempo-coordinator-k8scharm. - intended to be deployed on top of a COS Lite bundle to extend it with tracing.
In this documentation
| Tutorial Get started - a hands-on introduction for new users deploying the charmed operator. |
| Explanation Concepts - discussion and clarification of key topics |
Reference Technical information - specifications, APIs, architecture |
Project and community
Charmed prometheus is part of the Canonical Observability Stack. It is an open source project that warmly welcomes community projects, contributions, suggestions, fixes and constructive feedback.
- Read our Code of conduct
- Join the Discourse community forum
- Join the Matrix community chat
- Contribute on GitHub
Thinking about using the Canonical Observability Stack for your next project? Get in touch!
Navigation
| Level | Path | Navlink |
| 1 | Tutorials | Tutorials |
| 1 | How To | How To |
| 2 | set-limits | Configure CPU and memory limits for tempo-worker |
| 1 | Reference | Reference |
| 2 | tempo-worker-roles | Tempo Worker roles |
| 1 | Explanation | Explanation |
| 2 | worker-coordinator architecture | The worker-coordinator architecture |
Redirects
Mapping table
| Path | Location |
