Spark Job Submission To Kubernetes Cluster
The spark-client snap contains the Apache Spark spark-submit utility for Kubernetes distribution.
Pre-requisites
Before being able to use the spark-submit utility, make sure that you have a service account available. Note that for running applications as outlined in the following guide, you DON’T need to have administrative rights on the kubernetes cluster. The service account created by an administrator (more details on the functionalities here) already provides the minimal set of permission to run Spark jobs on the associated namespace on K8s.
Validating Setup with an Example Spark Job
In order to test the validity of your setup, we can launch the Pi example bundled with Apache Spark:
SPARK_EXAMPLES_JAR_NAME='spark-examples_2.12-3.4.1.jar'
spark-client.spark-submit \
--deploy-mode cluster \
--class org.apache.spark.examples.SparkPi \
local:///opt/spark/examples/jars/$SPARK_EXAMPLES_JAR_NAME 100
Note In case executor pods fail to schedule due to insufficient CPU resources (either locally or in CI/CD pipelines), issue fractional CPU requests.
The command above is using the default (spark) user. Following the example from the previous chapter, the command has two more parameters (--username, --namespace)… However since we’ve already set the same deploy-mode defaults for the user, that parameter can be skipped.
Such as:
--username demouser \
--namespace demonamespace \
In case you’d like to monitor your submission, you could easily do it on the level of K8 pods. Typically:
$ kubectl get pod
org-apache-spark-examples-sparkpi-bd526f87e1deb586-driver 0/1 Completed 0 18h
spark-pi-32f7f187e5c9ea7f-exec-3 0/1 Terminating 0 2m8s
$ kubectl logs -f org-apache-spark-examples-sparkpi-bd526f87e1deb586-driver
Adding Big Data to the mix
It’s time to test out with a real big data workload. Here we assume that
- the input data is placed in S3
- the code i.e. python script is also placed in S3 and reads from the provided input location.
- the destination directory for output is also in S3
To launch the Spark job in this scenario, make sure the S3 access related information is available to you. Then execute the following commands.
APP_NAME='my-pyspark-app'
NUM_INSTANCES=5
NAMESPACE=<namespace for your spark K8s service account>
K8S_SERVICE_ACCOUNT_FOR_SPARK=<your spark K8s service account>
S3_ACCESS_KEY=<your s3 access key>
S3_SECRET_KEY=<your s3 secret key>
S3A_CREDENTIALS_PROVIDER_CLASS=org.apache.hadoop.fs.s3a.SimpleAWSCredentialsProvider
S3A_ENDPOINT=<your s3 endpoint>
S3A_SSL_ENABLED=false
S3_PATH_FOR_CODE_PY_FILE=</path/to/your/python_script_in_S3.py>
spark-client.spark-submit --deploy-mode cluster --name $APP_NAME \
--conf spark.executor.instances=$NUM_INSTANCES \
--conf spark.kubernetes.namespace=$NAMESPACE \
--conf spark.kubernetes.authenticate.driver.serviceAccountName=$K8S_SERVICE_ACCOUNT_FOR_SPARK \
--conf spark.hadoop.fs.s3a.access.key=$S3_ACCESS_KEY \
--conf spark.hadoop.fs.s3a.secret.key=$S3_SECRET_KEY \
--conf spark.hadoop.fs.s3a.aws.credentials.provider=$S3A_CREDENTIALS_PROVIDER_CLASS \
--conf spark.hadoop.fs.s3a.endpoint=$S3A_ENDPOINT \
--conf spark.hadoop.fs.s3a.connection.ssl.enabled=$S3A_SSL_ENABLED \
--conf spark.hadoop.fs.s3a.path.style.access=true \
$S3_PATH_FOR_CODE_PY_FILE
Such configuration parameters can be provided via a spark-defaults.conf config file placed as described here.
- Either setting SPARK_HOME and placing the config as
$SPARK_HOME/conf/spark-defaults.conf. Or - Overriding SPARK_CONFS and placing the config as
$SPARK_CONFS/spark-defaults.conf
For example, with a spark-defaults.conf as provided below for reference, we can make the submit command much simpler.
spark.master=k8s://https://<MY_K8S_CONTROL_PLANE_HOST_IP>:<MY_K8S_CONTROL_PLANE_PORT>
spark.kubernetes.context=<PREFERRED_K8S_CONTEXT>
spark.app.name=<SPARK_APP_NAME>
spark.executor.instances=<NUM_INSTANCES>
spark.kubernetes.container.image=<CONTAINER_IMAGE_PUBLIC_REF>
spark.kubernetes.container.image.pullPolicy=<PULL_POLICY>
spark.kubernetes.namespace=<NAMESPACE_OF_PREFERRED_SERVICEACCOUNT>
spark.kubernetes.authenticate.driver.serviceAccountName=<PREFERRED_SERVICEACCOUNT>
spark.eventLog.enabled=false
spark.hadoop.fs.s3a.access.key=<S3_ACCESS_KEY>
spark.hadoop.fs.s3a.secret.key=s<S3_SECRET_KEY>
spark.hadoop.fs.s3a.aws.credentials.provider=org.apache.hadoop.fs.s3a.SimpleAWSCredentialsProvider
spark.hadoop.fs.s3a.endpoint=<S3_ENDPOINT_URI>
spark.hadoop.fs.s3a.connection.ssl.enabled=false
With a valid configuration file placed appropriately, the submit command becomes straightforward:
spark-client.spark-submit --deploy-mode cluster $S3_PATH_FOR_CODE_PY_FILE
The configuration defaults can be overridden as well in the submit command with --conf arguments as demonstrated previously.
