Setup Kubernetes and Spark Client Snap
In order to be able to work with Kubernetes, we first need to set up a Kubernetes cluster.
In this tutorial we use MicroK8s, which is the simplest production-grade conformant K8s. If you would like to run this tutorial on other K8s installation, please refer to the How-to setup environment user guide.
Setup MicroK8s
MicroK8s snap installation goes as simple as
sudo snap install microk8s --classic
It is also recommended to configure MicroK8s in a way, so that the corresponding user has admin rights on the cluster. This is needed since some parts of this tutorial will present the tooling that helps administrators to manage Spark user-accounts. Therefore, the K8s user associated with the kube-config file needs to be able to create different type of resources (e.g. service-accounts, roles, role-bindings, secrets, config-maps) to work properly.
sudo snap alias microk8s.kubectl kubectl
sudo usermod -a -G microk8s ${USER}
mkdir -p ~/.kube
sudo chown -f -R ${USER} ~/.kube
In order to make these changes effective, it is best to open a new shell (or log in, log out) so the permissions would become effective.
Make sure that the MicroK8s cluster is now up and running:
microk8s status --wait-ready
Note that this command will wait until the cluster is ready. Once this is indeed the case, it will print a summary of the services that are active.
At this point we can export the Kubernetes config file:
microk8s config | tee ~/.kube/config
MicroK8s also allows to enable some K8s features used by the Spark Client Snap (DNS resolution of pods and RBAC):
microk8s.enable dns
microk8s.enable rbac
The MicroK8s cluster is now ready to be used.
Setup Spark Client Snap
In order to install the spark-client snap on your local environment or on an edge node of a cluster, simply issue the following command:
sudo snap install spark-client --stable
This will install all the spark binaries along side with the spark-client utilities provided in
the snap.
As we will see in the following, the spark-client Snap can effectively be used by:
- cluster administrators, who create and manage Spark service accounts (as shown here)
- developers and data-scientists, who need to launch Spark Jobs (as shown here) or perform interactive analysis
using
pysparkandspark-shell(as shown here)
- Previous: Spark Client Snap Tutorial
- Next: Manage Spark service accounts
