How to setup a K8s cluster for Spark
The Charmed Spark solution requires an environment with:
- A Kubernetes cluster for running the services and workloads
- An Object storage layer to store persistent data
In the following guide, we provide details on the technologies currently supported and instructions on how these layers can be set up.
Kubernetes
The Charmed Spark solution runs on top of several K8s distributions. We recommend using versions above or equal to 1.29
Earlier versions may still be working, although we do not explicitly test them.
There are multiple ways that a K8s cluster can be deployed. We provide full compatibility and support for:
- MicroK8s
- AWS EKS
- Azure AKS (Coming Soon)
The how-to guide below shows you how to set up these to be used with Charmed Spark.
MicroK8s
MicroK8s is the mightiest tiny Kubernetes distribution around. It can easily installed locally via SNAPs
sudo snap install microk8s --classic
When installing MicroK8s, it is recommended to configure MicroK8s in a way, so that there exists a user that has admin rights on the cluster.
sudo snap alias microk8s.kubectl kubectl
sudo usermod -a -G microk8s ${USER}
mkdir -p ~/.kube
sudo chown -f -R ${USER} ~/.kube
To make these changes effective, you can either open a new shell (or log in, log out) or use newgrp microk8s
Make sure that the MicroK8s cluster is now up and running:
microk8s status --wait-ready
Export the Kubernetes config file associated with admin rights and store it in the $KUBECONFIG file, e.g. ~/.kube/config
export KUBECONFIG=path/to/file # Usually ~/.kube/config
microk8s config | tee ${KUBECONFIG}
Enable the K8s features required by the Spark Client Snap
microk8s.enable dns rbac storage hostpath-storage
The MicroK8s cluster is now ready to be used.
External LoadBalancer
If you want to expose the Spark History Server UI via a Traefik ingress, we need to enable external loadbalancer
IPADDR=$(ip -4 -j route get 2.2.2.2 | jq -r '.[] | .prefsrc')
microk8s enable metallb:$IPADDR-$IPADDR
AWS EKS
In order to deploy an EKS cluster, make sure that you have working CLI tools properly installed on your edge machine:
- AWS CLI correctly setup to use a properly configured service account (refer to here for configuration and here for authentication). Once the AWS CLI is configured, make sure that it works properly by testing the authentication call through the following command:
aws sts get-identity-caller
- eksctl installed and configure (refer to the [README.md] file for more information on how to install it)
Make also sure that your service account (configured in AWS) has the right permission to create and manage EKS clusters. In general, we recommend the use of profiles when having multiple accounts.
Creating a cluster
An EKS cluster can be created using eksctl
, the AWS Management Console, or the AWS CLI. In the following we will use eksctl
Create a YAML file with the following content
apiVersion: eksctl.io/v1alpha5
kind: ClusterConfig
metadata:
region: <AWS_REGION_NAME>
version: "1.27"
iam:
withOIDC: true
addons:
- name: aws-ebs-csi-driver
wellKnownPolicies:
ebsCSIController: true
nodeGroups:
- name: ng-1
minSize: 3
maxSize: 5
iam:
attachPolicyARNs:
- arn:aws:iam::aws:policy/AmazonEKSWorkerNodePolicy
- arn:aws:iam::aws:policy/AmazonEKS_CNI_Policy
- arn:aws:iam::aws:policy/AmazonEC2ContainerRegistryReadOnly
- arn:aws:iam::aws:policy/AmazonSSMManagedInstanceCore
- arn:aws:iam::aws:policy/AmazonS3FullAccess
instancesDistribution:
maxPrice: 0.15
instanceTypes: ["m5.xlarge", "m5.large"] # At least two instance types should be specified
onDemandBaseCapacity: 0
onDemandPercentageAboveBaseCapacity: 50
spotInstancePools: 2
Feel free to replace the <AWS_REGION_NAME>
with the AWS region of your choice, and custom further the above YAML based on your needs and policies in place.
You can then create the EKS via CLI
eksctl create cluster -f cluster.yaml
The EKS cluster creation process may take several minutes. The cluster creation process should already update the KUBECONFIG
file with the new cluster information. By default, eksctl
creates a user that generate new access token on the fly via the aws
CLI. However, this conflicts with the spark-client
snap that is strictly confined and does not have access to the aws
command. Therefore, we recommend you to manually retrieve a token, i.e.
aws eks get-token --region <AWS_REGION_NAME> --cluster-name spark-cluster --output json
and paste the token in the KUBECONFIG file
users:
- name: eks-created-username
user:
token: <AWS_TOKEN>
The EKS cluster is now ready to be used.
Object storage
Object storage persistence integration with Charmed Spark is critical for:
- reading and writing application data to be used in Spark Jobs
- storing Spark Jobs logs to be then exposed via Charmed Spark History Server
- enable Hive-compatible JDBC/ODBC endpoints provided by Apache Kyuubi to provide datalake capabilities on top of HDFS/Hadoop/object storages
Charmed Spark provides out-of-box integration with the following object storage backends:
- S3-compatible object storages, such as:
- MinIO
- AWS S3 bucket
- Azure Storage
- Azure Blob Storage
- Azure DataLake v2 Storage
In the following, we provide guidance on how to set up different object storages and how to configure them to make sure that it seamlessly integrates with Charmed Spark.
In fact, to store Spark logs on a dedicated directories, you need to create the appropriate folder (that is named spark-events
) in the storage backend.
This can be done both on S3 and on Azure DataLake Gen2 Storage. Although there are multiple ways to do this,
in the following we recommend you to use snap clients.
Alternatively, use Python libraries.
To connect Charmed Spark with an S3-compatible object storage, the following configurations need to be specified:
access_key
secret_key
endpoint
bucket
- (optional)
region
Leveraging on standard S3 API, you can use the aws-cli
snap client to perform operations with the
S3 service, like creating buckets, uploading new content, inspecting the structure, and removing data.
To install the AWS CLI client, use
sudo snap install aws-cli --classic
The client can then be configured using the parameters above with
aws configure set aws_access_key_id <S3_ACCESS_KEY>
aws configure set aws_secret_access_key <S3_SECRET_KEY>
aws configure set endpoint_url <S3_ENDPOINT>
aws configure set default.region <S3_REGION> # Optional for AWS only
Test that the AWS CLI client is properly working with
aws s3 ls
Supported S3 backends
In the following sections, we show how to setup and extract information for:
- MicroK8s MinIO
- AWS S3
MicroK8s MinIO
If you have already a MicroK8s cluster running, you can enable the MinIO storage with the dedicated addon
microk8s.enable minio
Refer to the add-on documentation for more information how to customize your MinIO MicroK8s deployment.
You can then use the following commands to obtain the access_key
, the secret_key
and the MinIO endpoint
access_key
:microk8s.kubectl get secret -n minio-operator microk8s-user-1 -o jsonpath='{.data.CONSOLE_ACCESS_KEY}' | base64 -d
secret_key
:microk8s.kubectl get secret -n minio-operator microk8s-user-1 -o jsonpath='{.data.CONSOLE_SECRET_KEY}' | base64 -d
endpoint
:microk8s.kubectl get services -n minio-operator | grep minio | awk '{ print $3 }'
Configure the AWS CLI snap with these parameters, as shown above. After that, you can create a bucket using
aws s3 mb s3://<S3_BUCKET>
AWS S3
In order to use AWS S3, you need to have an AWS user that has permission to use S3 resource for reading and writing. You can create a new user or use an existing one, as long as you grant permission to S3, either centrally using the IAM console or from the S3 service itself.
If the service account has the AmazonS3FullAccess
permission, you can create new buckets by using
aws s3api create-bucket --bucket <S3_BUCKET> --region <S3_REGION>
Note that buckets will be associated to a given AWS region. Once the bucket is created, you can use
the access_key
and the secret_key
of your service account, also used for authenticating with the AWS CLI profile.
The endpoint of the service is https://s3.<S3_REGION>.amazonaws.com
Setting Up the object Storage
To create a folder on an existing bucket, just place an empty path object spark-events
aws s3api put-object --bucket <S3_BUCKET> --key spark-events
The S3-object storage should now be ready to be used by Spark Jobs to store their logs.
Azure Storage
Charmed Spark provides out-of-the-box support also for the following Azure storage backends:
- Azure Blob Storage (both WASB and WASBS)
- Azure DataLake Gen2 Storage (ABFS and ABFSS)
Note that Azure DataLake Gen1 Storage is currently not supported, and it has been deprecated by Azure.
In order to connect Charmed Spark with the Azure storage backends (WASB, WASBS, ABFS and ABFSS) the following configurations need to be specified:
storage_account
storage_key
container
You can use the azcli
snap client to perform operations with the Azure storage services,
like creating buckets, upload new content, inspecting the structure and removing data.
To install the azcli
client, use
sudo snap install azcli
The client needs to be configured using the Azure storage account and the associated storage key. These credentials can be retrieved from the Azure portal, after creating a storage account. When creating the storage account, make sure that you enable āHierarchical namespaceā if you want to use Azure DataLake Gen2 Storage (which is assumed by default unless configured otherwise).
Once you have those information, the client can be configured by using the following environment variables:
export AZURE_STORAGE_ACCOUNT=<storage_account>
export AZURE_STORAGE_KEY=<storage_key>
Now test that the azcli
azcli storage container list
Once the credentials are set up, you can create a container in your namespace either from the portal
or also using the azcli
with
azcli storage container create --fail-on-exist --name <AZURE_CONTAINER>
To create a folder on an existing container, just place a dummy file in the container under the spark-events
path.
For doing this, you can use the azcli
client snap.
azcli storage blob upload --container-name <AZURE_CONTAINER> --name spark-events/a.tmp -f /dev/null
