Manage Spark Client Accounts
This is an introduction to the CLI interface for creating, managing and configuring Spark accounts.
Note The following commands assume that you have administrative permission on the namespaces (or on the kubernetes cluster) such that the corresponding resources (such as service accounts, secrets, roles and role-bindings) can be created and deleted.
Create Service Account
Note: In case using another namespace than default
, make sure that it already exists in Kubernetes.
$ kubectl create namespace demonamespace
namespace/demonamespace created
Now we can define a service account within the scope of this namespace. In case we may have a configuration file with default settings for the account, we could also include those when defining the account. The syntax of the config file is identical to Spark Configuration Properties. For example
$ echo "spark.kubernetes.deploy-mode=cluster" > /home/demouser/conf/spark-overrides.conf
The command below creates a service account associated with configuration properties provided either via property file or explicit
configuration arguments. The flags --primary
specifies that the newly created account will be the primary account to
be used. (If another primary exists, the latter account primary flag will be set to false
spark-client.service-account-registry create --username demouser --namespace demonamespace --primary --properties-file /home/demouser/conf/spark-overrides.conf --conf spark.app.name=demo-spark-app-overrides
List all service accounts
The command below displays a list of the service accounts available, and whether they are primary account or service accounts
spark-client.service-account-registry list
Add more entries to Service Account Configuration
The command below will upsert into the existing configuration associated with the account.
spark-client.service-account-registry add-config --username demouser --namespace demonamespace --properties-file /home/demouser/conf/spark-overrides.conf --conf spark.app.name=demo-spark-app-overrides
Remove entries from Service Account Configuration
The command below will remove the specified keys from existing configuration associated with the account.
spark-client.service-account-registry remove-config --username demouser --namespace demonamespace --conf conf.key1.to.remove --conf conf.key2.to.remove
Print configuration for a given Service Account
This command will print the configuration for a given service account.
spark-client.service-account-registry get-config --username demouser --namespace demonamespace
Delete Service Account Configuration
This command will delete the configurations associated to a given service account.
spark-client.service-account-registry clear-config --username demouser --namespace demonamespace
Inspect Primary Service Account
This command will allow the user to find out which is the primary account, together with related configuration settings.
spark-client.service-account-registry get-primary
Cleanup a Service Account
This command will delete the service account together with the other resources created, e.g. secrets, role, role-bindings, etc.
spark-client.service-account-registry delete --username demouser --namespace demonamespace
