Juju version
The charm supports both Juju 2.9 LTS and Juju 3.1.
The minimum supported Juju versions are:
- 2.9.32+
- 3.1.7+ (Juju secrets refactored/stabilized in Juju 3.1.7)
Minimum requirements
Make sure your machine meets the following requirements:
- Ubuntu 22.04 (Jammy) or later.
- 8GB of RAM.
- 2 CPU threads.
- Access to the internet for downloading the required OCI/ROCKs and charms.
Supported architectures
The charm is based on SNAP “charmed-postgresql”, which is currently available for amd64 and arm64 (revision 173+). Please contact us if you are interested in new architecture!
Charmed PostgreSQL requirements
Please also keep in mind “Charmed PostgreSQL” requirements.
