Releases
This page provides high-level overviews of the dependencies and features that are supported by each revision in every stable release. To learn more about the different release tracks, see the Juju documentation about risk levels.
To see all releases and commits, check the Charmed PgBouncer Releases page on GitHub.
Dependencies and supported features
For each release, this table shows:
- The PgBouncer version packaged inside
- The minimum Juju version required to reliably operate all features of the release
This charm still supports older versions of Juju 2.9. See the system requirements for more details
- Support for specific features
| Release | PgBouncer version | Juju version | PostgreSQL 16 on 24.04 | TLS encryption | COS monitoring | Minor version upgrades |
| 1083, 1084, 1090, 1091, 1092, 1093 | 1.21.0 |
3.6.24+ |
| 1017, 1018, 1019, 1020, 1021, 1022 | 1.21.0 |
3.6.1+ |
| 909, 910, 911, 912, 913, 914 | 1.21.0 |
3.6.1+ |
| 897, 898, 899, 900, 901, 902 | 1.21.0 |
3.6.1+ |
| 873, 874, 875, 876, 877, 878 | 1.21.0 |
3.6.1+ |
| 639, 640, 641, 642 | 1.21.0 |
3.6.1+ |
| 394, 395, 396, 397 | 1.21.0 |
3.4.5+ |
| 278, 279, 280, 281 | 1.21.0 |
3.4.5+ |
| 254, 255, 256, 257 | 1.21.0 |
3.1.8+ |
| 173, 174, 175, 176 | 1.21.0 |
3.1.8+ |
| 88, 89 | 1.21.0 |
3.1.7+ |
| 80, 81 | 1.21.0 |
3.1.6+ |
| 76, 77 | 1.18.0 |
3.1.6+ |
Architecture and base
Due to the subordinate nature of this charm, several revisions are released simultaneously for different bases/series using the same charm code. In other words, one release contains multiple revisions.
If you do not specify a revision on deploy time, Juju will automatically choose the revision that matches your base and architecture.
See:
juju info.
Release 1083-1093
| Revision | amd64 |
arm64 |
Ubuntu 20.04 (focal) | Ubuntu 22.04 (jammy) | Ubuntu 24.04 (noble) |
| 1093 | |||||
| 1092 | |||||
| 1091 | |||||
| 1090 | |||||
| 1084 | |||||
| 1083 |
Older releases
Release 1017-1022
| Revision | amd64 |
arm64 |
| 1017 | |||||
| 1018 | |||||
| 1019 | |||||
| 1020 | |||||
| 1021 | |||||
| 1022 |
Release 909-914
| Revision | amd64 |
arm64 |
| 909 | |||||
| 910 | |||||
| 911 | |||||
| 912 | |||||
| 913 | |||||
| 914 |
Release 897-902
| Revision | amd64 |
arm64 |
| 897 | |||||
| 898 | |||||
| 899 | |||||
| 900 | |||||
| 901 | |||||
| 902 |
Release 873-878
| Revision | amd64 |
arm64 |
| 878 | |||||
| 877 | |||||
| 876 | |||||
| 875 | |||||
| 874 | |||||
| 873 |
Release 639-642
Release 394-397
Release 278-281
Release 257-254
Release 173-176
Release 88-89
Release 80-81
Release 76-77
Note: Our release notes are an ongoing work in progress. If there is any additional information about releases that you would like to see or suggestions for other improvements, don’t hesitate to contact us on Matrix or leave a comment.
