Enable tracing
This guide contains the steps to enable tracing with Grafana Tempo for your PgBouncer K8s application.
To summarize:
- Deploy the Tempo charm in a COS K8s environment
- Offer interfaces for cross-model integrations
- Consume and integrate cross-model integrations
- View PgBouncer K8s traces on Grafana
This feature is available for Charmed PgBouncer K8s revision 162+ only.
- Have deployed a Charmed PostgreSQL K8s application
- Have deployed a Charmed PgBouncer K8s application in the same model as the Charmed PostgreSQL K8s applicatoin
- Have deployed a ‘cos-lite’ bundle from the
latest/edgetrack in a Kubernetes environment
Deploy Tempo
Then, deploy the dependencies of Tempo by following this tutorial. In particular, we would want to:
- Deploy the minio charm
- Deploy the s3 integrator charm
- Add a bucket in minio using a python script
- Configure s3 integrator with the minio credentials
Finally, deploy and integrate with Tempo HA in a monolithic setup.
Offer interfaces
Next, offer interfaces for cross-model integrations from the model where Charmed PgBouncer K8s is deployed.
juju offer <tempo_coordinator_k8s_application_name>:tracing
Then, switch to the Charmed PgBouncer K8s model, find the offers, and integrate (relate) with them:
juju switch <k8s_controller_name>:<pgbouncer_k8s_model_name>
Do not miss the “
:” in the command above.
Store URL Access Interfaces
k8s admin/cos.tempo admin tracing:tracing
juju consume k8s:admin/cos.tempo
Consume interfaces
Relate Charmed PgBouncer K8s with the above consumed interface:
First, deploy Grafana Agent K8s from the latest/edge channel:
juju deploy grafana-agent-k8s --channel latest/edge
Then, integrate Grafana Agent K8s with the consumed interface from the previous section:
juju integrate grafana-agent-k8s:tracing tempo:tracing
Finally, integrate Charmed PgBouncer K8s with Grafana Agent K8s:
juju integrate pgbouncer-k8s:tracing grafana-agent-k8s:tracing-provider
Wait until the model settles. The following is an example of the juju status --relations on the Charmed PgBouncer K8s model:
database k8s microk8s/localhost 3.5.4 unsupported 18:12:15Z
SAAS Status Store URL
tempo active k8s admin/cos.tempo
grafana-agent-k8s 0.40.4 active 1 grafana-agent-k8s latest/edge 93 10.152.183.52 no grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
pgbouncer-k8s 1.21.0 active 1 pgbouncer-k8s 0 10.152.183.202 no
postgresql-k8s 14.13 active 1 postgresql-k8s 14/edge 410 10.152.183.168 no
postgresql-test-app active 1 postgresql-test-app latest/stable 211 10.152.183.174 no received database credentials of the first database
grafana-agent-k8s/0* active idle 10.1.241.205 grafana-dashboards-provider: off, logging-consumer: off, send-remote-write: off
pgbouncer-k8s/0* active idle 10.1.241.202
postgresql-k8s/0* active idle 10.1.241.204 Primary
postgresql-test-app/0* active idle 10.1.241.203 received database credentials of the first database
grafana-agent-k8s:peers grafana-agent-k8s:peers grafana_agent_replica peer
grafana-agent-k8s:tracing-provider pgbouncer-k8s:tracing tracing regular
pgbouncer-k8s:database postgresql-test-app:database postgresql_client regular
pgbouncer-k8s:pgb-peers pgbouncer-k8s:pgb-peers pgb_peers peer
pgbouncer-k8s:upgrade pgbouncer-k8s:upgrade upgrade peer
postgresql-k8s:database pgbouncer-k8s:backend-database postgresql_client regular
postgresql-k8s:database-peers postgresql-k8s:database-peers postgresql_peers peer
postgresql-k8s:restart postgresql-k8s:restart rolling_op peer
postgresql-k8s:upgrade postgresql-k8s:upgrade upgrade peer
postgresql-test-app:postgresql-test-peers postgresql-test-app:postgresql-test-peers postgresql-test-peers peer
tempo:tracing grafana-agent-k8s:tracing tracing regular
View traces
After this is complete, the Tempo traces will be accessible from Grafana under the Explore section with tempo-k8s as the data source. You will be able to select pgbouncer-k8s as the Service Name under the Search tab to view traces belonging to Charmed PgBouncer K8s.
Below is a screenshot demonstrating a Charmed PgBouncer K8s trace:
Feel free to read through the Tempo HA documentation at your leisure to explore its deployment and its integrations.
