How to enable encryption
PgBouncer is a subordinate charm. When integrated to a host application (principal charm), it serves on localhost, so TLS encryption is not necessary.
If you are using data-integrator, PgBouncer will open a port to listen to TCP traffic. In this case, because PgBouncer is exposed, TLS encryption is recommended.
Enable TLS
First, deploy the TLS charm:
juju deploy self-signed-certificates --config ca-common-name="Tutorial CA"
To enable TLS, integrate the two applications:
juju integrate self-signed-certificates pgbouncer
To enable TLS on PostgreSQL, refer to Charmed PostgreSQL | How to enable security.
