Please update your bookmarks, and contact us if you have any questions.
A Jujucharm deploying and managing external access to HTTP/HTTPS services in a Kubernetes cluster via an Nginx Ingress resource. This requires the Kubernetes cluster in question to have an Nginx Ingress Controller already deployed into it.
This charm simplifies exposing services running inside a Kubernetes cluster to external clients. It offers TLS termination as well as easy configuration of a number of advanced features including rate limiting, restricting access to specific client IP source ranges, and OWASP ModSecurity Core Rule Set (CRS).
As such, the charm makes it easy for charm developers to provide external access to their HTTP workloads in Kubernetes by easy integration offered via the charm’s nginx_route library.
For DevOps and SRE teams, providing ingress for charms that support a relation to this charm will be possible via a simple juju relate command.
Hi @mthaddo,
congratulations for your post.
Considering I’m a beginner, I apologize if I don’t have much foundation for what I’m looking for.
Can you tell me which address I access hello-kubecon from after succeeding with
juju relate ingress hello-kubecon
I think I must have a problem with the AWS/Eks cluster. The description informs that the endpoint was not found during the entry process.
It would be the IP of your Nginx Ingress Controller. If I’m running this on microk8s that’s exposed on 127.0.0.1 (as long as I’ve enabled the ingress add-on), but since I think you’re running this on AWS/EKS you may need to deploy an Nginx Ingress Controller first, and then connect to hello-kubecon on the IP address of that ingress controller.
This charm doesn’t deploy an Ingress Controller itself, it simply generates an Nginx Ingress resource that can then be used by an Nginx Ingress Controller. Ingress is a pretty involved topic in Kubernetes and there are lots of different ways to do things!
