Nginx ingress integrator docs - charm architecture
Our docs have moved to a new home!
Please update your bookmarks, and contact us if you have any questions.
Charm architecture
At its core, Nginx Ingress Integrator is a basic charm that talks to the Kubernetes API and provisions an Nginx ingress resource.
In designing this charm, we’ve leveraged the sidecar pattern for Kubernetes charms, but somewhat unusually we’re not actually deploying a workload container alongside our charm code. Instead, the charm code talks directly to the Kubernetes API to provision the appropriate Nginx ingress resource to enable traffic to reach the service in question.
As a result, if you run a kubectl get pods on a namespace named for the Juju model you’ve deployed the nginx-ingress-integrator charm into, you’ll see something like the following:
NAME                             READY   STATUS    RESTARTS   AGE
nginx-ingress-integrator-0       1/1     Running   0          3h47m
This shows there is only one container for the charm code itself.
Structure of the charm
The Nginx Ingress Integrator receives ingress requests from application charms via either the ingress integration or the nginx-route integration. The ingress integration is more prevalent, as it is the same integration supported by many other charms, including the traefik-k8s charm. The nginx-route integration is more specific to the Nginx Ingress Integrator but offers more customization of the ingress specification.
When the Nginx Ingress Integrator receives an ingress request from an application charm, via either the ingress integration or the nginx-route integration, it unifies the request into an intermediate representation and then converts this representation into the desired Kubernetes resources, including ingress resources , service resources , EndpointSlice resources , and secret resources , among others. This process creates the ingress needed to route traffic to the application charm as requested.
The Nginx Ingress Integrator can also integrate with tls-certificate provider charms and use the certificates provided by these charms as the server certificates for ingress.
Handling of ingress integration
The ingress integration is a universal integration that may be used in Juju VM models or Juju Kubernetes models, unlike the nginx-route integration, which is designed exclusively for use within Juju Kubernetes models. Therefore, the Nginx Ingress Integrator cannot make many assumptions about the application requiring ingress. For this reason, the ingress for ingress integrations is built based on Kubernetes EndpointSlice resources, using IP addresses provided in the ingress integration. In contrast, the nginx-route integration is based on service resources with selectors.
OCI images
Nginx Ingress Integrator charm doesn’t use any OCI image resources.
Juju events
For this charm, the following Juju events are observed:
  1. config-changed
  2. start
  3. get-certificate-action
  4. data-provided from ingress charm library
  5. data-removed from ingress charm library
  6. certificate_available from tls_certificates charm library
In addition, the charm libraries can observe many other events. For more details, see the documentation for the charm libraries.
Charm code overview
The src/charm.py is the default entry point for a charm and has the NginxIngressCharm Python class which inherits from CharmBase. CharmBase is the base class from which all Charms are formed, defined by Ops (Python framework for developing charms).
See more in the Juju docs: Charm
The __init__ method guarantees that the charm observes all events relevant to its operation and handles them.
Take, for example, when a configuration is changed by using the CLI.
  1. User runs the configuration command:
juju config <relevant-charm-configuration>
  1. A config-changed event is emitted.
  2. In the __init__ method is defined how to handle this event like this:
self.framework.observe(self.on.config_changed, self._on_config_changed)
  1. The method _on_config_changed, for its turn, will take the necessary actions such as waiting for all the relations to be ready and then configuring the containers.
Charm architecture diagram
The Nginx Ingress Integrator charm uses the ingress, tls_certificates and nginx_route charm libraries to handle charm integrations. It also uses the Kubernetes Python client, which is wrapped in custom modules to reconcile the Kubernetes resources necessary for ingress.
C4Context
    System_Boundary(nginx-ingress-integrator, "Nginx Ingress Integrator") {
        Container_Boundary(charm-lib, "Charm Libraries") {
            Component(nginx-route-lib, "nginx_ingress_integrator.v0.nginx_route")
            Component(tls-certificates-lib, "tls_certificates_interface.v4.tls_certificates")
            Component(ingress-lib, "traefik_k8s.v2.ingress")
        Container_Boundary(charm, "Charm Logic") {
            Component(nginx-ingress-integrator-charm, "Nginx Ingress Integrator Charm")
        Container_Boundary(kubernetes-lib, "Kubernetes Libraries") {
            Component(endpoint-slice, "EndpointSlice")
            Component(endpoint, "Endpoint")
            Component(ingress, "Ingress")
            Component(secret, "Secret")
            Component(service, "Service")
        Rel(nginx-route-lib, nginx-ingress-integrator-charm, "Ingress Spec")
        Rel(tls-certificates-lib, nginx-ingress-integrator-charm, "Server Cert")
        Rel(ingress-lib, nginx-ingress-integrator-charm, "Ingress Spec")
        Rel(nginx-ingress-integrator-charm, endpoint-slice, "Reconciliation")
        Rel(nginx-ingress-integrator-charm, endpoint, "Reconciliation")
        Rel(nginx-ingress-integrator-charm, ingress, "Reconciliation")
        Rel(nginx-ingress-integrator-charm, secret, "Reconciliation")
        Rel(nginx-ingress-integrator-charm, service, "Reconciliation")
        UpdateLayoutConfig($c4ShapeInRow="1", $c4BoundaryInRow="4")
        UpdateRelStyle(nginx-route-lib, nginx-ingress-integrator-charm , $offsetY="-15", $offsetX="-5")
        UpdateRelStyle(tls-certificates-lib, nginx-ingress-integrator-charm, $offsetY="0", $offsetX="-120")
        UpdateRelStyle(ingress-lib, nginx-ingress-integrator-charm, $offsetY="70", $offsetX="-140")
        UpdateRelStyle(nginx-ingress-integrator-charm, endpoint-slice, $offsetY="-10", $offsetX="-20")
